Old 09-05-2016, 08:16 AM   #11
DW's Retirement Plan
DaGrinch's Avatar
The last two times out, I've had to do the "remove panel, unplug for 30 seconds" bit. I keep my unit plugged in here in the driveway and still have had issues. And yes, I also am connected to shore power when I try to put the levelers down. I'm about ready to put wingnuts on the panel screws. Although, one person says to install a switch on the hot wire. Still, shouldn't have to do that.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 09-05-2016, 08:57 AM   #12
Chief tinkerer
Gidyupgo's Avatar
Right Grinch. Shouldn't have to. Hmmm I wonder if it would be easier to pull the fuse if it's in that panel below the Bigfoot panel?
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-05-2016, 06:45 PM   #13
KJcachers's Avatar
Originally Posted by Witch Doctor View Post
I always plug in before using mine, it takes a lot of juice, and I disconnect the plug last after I bring the jacks up. You should be able to cycle the screen to show you the battery voltage is before you start, so then you will know if you should be plugged in, but that is just my routine that I use and everyone has there own sequence when they arrive and depart...
I do this as well, for both the slide and the jacks
2015 Forester 3051s
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 09-05-2016, 06:55 PM   #14
KJcachers's Avatar
Originally Posted by vwexpert View Post
GL...why did they change your refrigerator door? Mine won't stay shut (right side)...they ordered a new plastic latch but I think it more than that.
Jim
Here's how I fixed mine.
https://youtu.be/pqgPEtsXCIY
2015 Forester 3051s
Jason and Karen
2015 Forester 3051S
jacks
