Old 07-22-2015, 09:57 PM   #21
Bus Driver
Deaver's Avatar
Originally Posted by benagi View Post
I ordered the above roller but big problem.
Sorry Ben for the Non-Fit. Hope you are able to work it out
2012 Forest River Forester 25651S - The Magic Bus
Just trying to be the person my Dog thinks I am
Deaver is offline   Reply With Quote
Old 07-22-2015, 10:11 PM   #22
benagi's Avatar
NP Deaver, we'll figure it out.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-23-2015, 01:33 PM   #23
IMO if you are dragging the rear so much you think you need a roller I would be figuring out some way to drag less. When you drag the rear you put undue stress on the rear frame rail extensions and fiberglass coach in an upward direction instead of a normal designed downward load. The lower sides around the hatches and bottom of the slide cutouts go from normal compression loading to tension which can cause cracks at the corners of the openings. This is not an issue for infrequent minor dragging but the rollers will only mask severe dragging that can damage things. If you put on rollers make sure they are only as low as absolutely needed to protect the receiver. Also if you don't use the hitch or rarely use it, why not remove it and reinstall only when needed.
ATVer is offline   Reply With Quote
Old 07-23-2015, 02:31 PM   #24
benagi's Avatar
Our unit drags out in the street every time we pull in and out of our driveway. We did move all the heavy stuff in the back to the front, so there is less dragging. As I stated above, we had to send the roller back because it will not fit on the existing receiver hitch. So we didn't even get to test it. We will be pulling a boat occasionally. Curious to see how much it will drag then.
1968 tent trailer
1985 Jamboree 23 ft
Old 07-23-2015, 03:41 PM   #25
Could have tried this hitch extender: https://www.etrailer.com/Hitch-Acces...rt/C45791.html
Place the skid wheel on the extender receiver without the interference of the chain hooks of the chassis receiver.
Yea - it's sticking the receiver out there and it could exert quite a bit of force (weight) on the extender/receiver however, its pick your evils. Either drag on lift pads, receiver, receiver skids or use the extender with the skid wheel.
I have a receiver splitter so that I can tow my toad and carry my bike rack: https://www.etrailer.com/Accessories.../RM-077-4.html
I considered installing my skid wheel on that. I no longer need the splitter since I have added a receiver on the front of the coach and place my bike rack up there. I didn't care for the bikes hanging so close to the front of the toad.
Bobby
bgilly is offline   Reply With Quote
Old 07-23-2015, 03:53 PM   #26
papap's Avatar
Going to drive mine without roller. Then decide if I'm just going to weld the roller to hitch if needed,
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-05-2015, 08:09 PM   #27
What is the optimum pressure for the Firestone air bags in the rear of my Forester? I don't think mine was ever inflated.
coldj is offline   Reply With Quote
Old 08-05-2015, 08:55 PM   #28
Boso's Avatar
Don't think many use rollers just air up bags I thought about roller when I first got mine but it never drags when aired up 75psi but mine have been leaking down to as low as 45psi still don't drag leaving driveway or over curbing
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 08-05-2015, 08:55 PM   #29
65-70 lbs. IMO
steverkemp is offline   Reply With Quote
Old 08-05-2015, 08:56 PM   #30
+1
Old 08-05-2015, 09:21 PM   #31
Bus Driver
Deaver's Avatar
Firestone states a minimum of 5 Lbs. I agree with steverkemp, 65-70 Lbs
I like a little weight shift to the front and use the same range. I find mine handles better in this range as well
Old 08-06-2015, 05:10 AM   #32
Wait till next year...
n-e-d's Avatar
X2 Deaver, Run my air bags at 70#. First two trips at ? pounds were a little discerning thought the steering box wacked. Fixed the airline to the bags pumped them up and last trip was unbelieveably better
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 08-06-2015, 01:24 PM   #33
benagi's Avatar
X2 Deaver, Run my air bags at 70#. First two trips at ? pounds were a little discerning thought the steering box wacked. Fixed the airline to the bags pumped them up and last trip was unbelieveably better[/QUOTE]
Ned, did it feel like you had a lot of play in the steering? Thx, Ben
1968 tent trailer
1985 Jamboree 23 ft
Old 08-06-2015, 02:31 PM   #34
n-e-d's Avatar
Yes Like I said I thought the problem was the steering box. Spent 6 hours turning wheel 2-3 inches to right then back to the left then back again to keep MH in a straight line. Fixed the problem I had with my airbags and drove lots better
Mary and Me
Old 08-06-2015, 04:40 PM   #35
papap's Avatar
I installed the wireless air system on mine. I had trouble with the filter not working correctly. They over nighters me a new filter. It works great now. I pressure mine up to drive then drop the pressure off before leveling camper with lift system.
Old 08-06-2015, 05:33 PM   #36
benagi's Avatar
Papap, what system are you using? Does it come with the compressor, and if so, where did you install it?
1968 tent trailer
1985 Jamboree 23 ft
Old 08-06-2015, 05:37 PM   #37
papap's Avatar
This is what I installed. I put mine inside the compartment right in front of the back driver side wheels. Keeps it out the weather. I call and asked them about this before doing the install. They said it was a great place to install it.
Amazon.com: AIR LIFT 72000 Wireless Air Leveling Compressor: Automotive
Old 08-06-2015, 06:21 PM   #38
papap's Avatar
Power hook up
This is how I hooked mine up. I got the idea from Oldflat on here. It works great this way. Bout part at Auto parts store. Less than $10.
Old 08-06-2015, 07:03 PM   #39
n-e-d's Avatar
I really like papap's air compressor system. I have a buddy who swears by his on a Ford dually TV. But I just ordered the TST 507 TPMS with 2 extra monitors figuring I'll keep an eye on air bag pressures and how the rig handles at varing pressures before jumping on a compressor
Mary and Me
Old 08-06-2015, 11:36 PM   #40
Bus Driver
Deaver's Avatar
The Air Lift Wireless Air System is a little cheaper - HERE
