Old 07-16-2018, 11:48 AM   #1
Rick.'s Avatar
Lights replacement
I have the 2801 and was trying to fix one of our lower accent lights that was out it had loss wiring and when I pulled on the wire fell out of the light? Playing around with it - both wires touched and blow out both and now I don’t know if it has a fuse on it? I hear the relay pulling in when I hit the one controller switch on, but no electric now on both light fixtures? Has anyone tried to replace with new fixture?
Rick. is offline   Reply With Quote
Old 07-16-2018, 12:56 PM   #2
Certified Curmudgeon
Gonna need an interpreter.
Does “lower accent lights” mean one of the two nightlights? One being in the step well and the other in the bath room at the base of the vanity?
Mike Dropped
Duckogram is offline   Reply With Quote
Old 07-16-2018, 01:01 PM   #3
Rick.'s Avatar
Yes you are correct, on the one control that is what was named? So I went with that, sorry.
Old 07-16-2018, 01:03 PM   #4
Rick.'s Avatar
Old 07-16-2018, 01:15 PM   #5
OK, Sunseeker does not have One Control but everything else is pretty much the same.
You can remove that lamp by unscrewing the two square drives. You can also access the back of that lamp by removing the service panel under the fridge.
When the wires shorted, you probably popped a breaker. So open the power center door and check to see if the little black tab is out on one of them. And for those who need to know, this model has 3 fuses in PD box. Those are for reverse polarity protection. The rest are breakers, AC and DC.
Mike Dropped
Old 07-17-2018, 09:04 PM   #6
Rick.'s Avatar
Yes thank you for the information, I haven't had a chance to check the breakers in the RV, it's been so hot and humid to be screwing around with it. I'm also still waiting on the dealer to return my call about the replacement light. Again thank you
light, replacement
