Originally Posted by JerrySull
I have a new Forester Class C 3011 which has the My RV control panels and can be controlled by the phone App.
I have had good luck with it but this last trip the outside light over the exterior shower is not responding to be turned off by any location or device.
It just stays on until I turn off the main 12v switch.
Any suggestions?
This is called the "scare light" on my 3051.
Try all lights off if your tablet or phone app has that choice.
When you turn off the 12 volt disconnect, leave it off for a few minutes so the router and tablets will reboot when you turn it back on.
The light control module may be located behind the panel on the left of your stairwell if you're comfortable checking for a loose connection.
What is that light labeled on your tablet?
