Old 03-31-2018, 03:43 PM   #1
Sagecoachdriver's Avatar
Little Red Campfire adapter to big tank
Has anyone come across an adapter for the Little Red Campfire that will allow me to hook up to my Forester's propane tank? I have the Extend-A Stay fitting on my motor home's tank and can attach my bar-b-que or a portable tank. But the Little Red Campfire comes with a portable tank adapter as shown in the photo. Maybe change out the hose itself, but it needs the regulator?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 8 trips 30 nights
Sagecoachdriver is offline   Reply With Quote
Old 03-31-2018, 04:10 PM   #2
dbledan's Avatar
Are you hooking up before or after your trailers regulator?
dbledan is offline   Reply With Quote
Old 03-31-2018, 04:14 PM   #3
It's not a trailer, it's a motorhome with a built in horizontal 12 gallon tank. The Extend-A-Stay is between the tank outlet and the regulator. As you can see there is a regulator on the Little Red Campfire's hose.
Old 03-31-2018, 05:21 PM   #4
Tombsy's Avatar
I think you need one of these
https://www.homedepot.com/p/Camco-Ca...9213/206813638
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is online now   Reply With Quote
Old 03-31-2018, 06:27 PM   #5
dbledan's Avatar
Yea depends on what your extended stay connector looks like. From the sound of it you will be hooking up before the regulator so Tombsy is right if you have the mini adaptor available on it then you just screw the campfire regulator on to that adaptor. If not you may need both that and this.
https://www.etrailer.com/Propane/MB-...03612-MBS.html
Old 03-31-2018, 06:48 PM   #6
dbledan, That looks just like my Extend-A-Stay. Looks like I need an adapter with 2 brass ends. Just saw one at CW for $65. May work, but I want to see if there is something cheaper. It would give me a lot of extra hose.
Old 03-31-2018, 06:53 PM   #7
dbledan's Avatar
The one Tombsy sent the link on was only $25 and you could get a small hose extension as well. You may be able to get a Y adaptor as well but those are $25 too.
Good luck hope it works out.
Old 04-02-2018, 09:05 AM   #8
I was able to buy an adapter for my gas fireplace on Amazon. If you are tapping into your RV the gas is all ready regulated so you need to eliminate the regulator on the fireplace. Same situation for my Coleman grill. Just check the fittings and match them to the hose.
Sorry reread your post, sounds like the extend a stay is an input for your system to allow connection of an external bottle. Match the fitting then put an in line regulator to the same spec as the one on the fireplace and you should be good to go.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 04-02-2018, 02:10 PM   #9
Jperry's Avatar
Lot Less Money than the Camco at Home Depot
https://www.amazon.com/KIBOW-Propane...l+bottle&psc=1
Jperry is offline   Reply With Quote
Old 04-09-2018, 12:19 PM   #10
Originally Posted by Jperry View Post
Thanks Jperry, that's the right adapter. Got it yesterday using Amazon Prime. Much cheaper than the Home Depot one.
tank
