On my 2015 2401R the battery disconnect is located on the cabinet panel left side as you enter the coach. It's a rotary switch. Important to remember that it does not disconnect all 12v devices - CO/propane sensor, slides (maybe), jacks (maybe). Don't remember for sure, over a year ago that I tested. Suggest that you "disconnect" and try everything 12v and see what works. The transfer switch is automatic, nothing for you to do. It monitors incoming Ac, and if not present, cuts thru the generator Ac output if the Genny is running.
