Old 10-30-2018, 06:18 PM   #1
Low point drains
I have a Class C 2016 Forest River Forester 3171DS. Can anyone tell me where the low point drains are located? Thanks.
willema is offline   Reply With Quote
Old 10-30-2018, 06:33 PM   #2
Usually Confused Member
emm-dee's Avatar
I assume youíre needing that info prior to winterizing. Good start here:
Winterizing
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 10-30-2018, 08:49 PM   #3
No need to winterize. Looking for the low point drain.
Old 10-31-2018, 07:56 AM   #4
I am new but I found the low water point drains (blue and red hoses) almost directly under but toward the edge of my fresh water tank (they are hanging down), the valve by the water pump drains the freshwater tank through the blue hose and then I go under and unscrew the cap on the red hose to drain the water lines etc. My 2018 2501TS includes a pickup tube and valve for the antifreeze to the water pump.
Emm-dee and any other "veteran" please correct anything wrong in what I have stated. Bad info is much worse than no info.
Again, I am brand new and the above is based on my hands on finding the hoses and valves with much help from this site. The winterize thread has pictures of the low point drain hoses.
v/r rch
RHOUSER is offline   Reply With Quote
Old 10-31-2018, 08:33 AM   #5
emm-dee's Avatar
v/r rch
You are correct. I added a quick drain to my Forester which keeps me from having to empty the storage compartment in order to access the drain valve.
Old 10-31-2018, 01:18 PM   #6
sgtlm17's Avatar
That is correct. The blue line should be for your fresh water holding tank drain. There should be a quarter turn valve in the pump compartment to drain. The red and only low point drain has a cap on it. The line is red to remind you it will only drain both hot and cold water lines when the water heater is in bypass mode.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
drain
