Old 04-16-2016, 02:14 AM   #11
Originally Posted by Sagecoachdriver View Post
I was told the same thing that they weren't needed on on a daily basis as the motors keep it in. But does if you manually have to bring it in, do you need the rods. If I remove the motors on the bedroom Schwintek, what's to hold it in? The Lippert above floor system has the 5/8" nut to turn with a ratchet, will the motor still hold it in?
If you brought the "Above Floor Slide" in with the Manual wrench/nut/drive the slide Will stay in place because of the Gearbox reduction gears! Youroo!!
youroo is online now   Reply With Quote
Old 04-16-2016, 10:36 AM   #12
Sagecoachdriver's Avatar
My concern and Ben's too?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 04-16-2016, 03:25 PM   #13
I am on your answer! My reply was No Slide locks needed,If you retracked it with the Nut drive! Youroo!!
Old 04-16-2016, 04:14 PM   #14
OK, case closed on Lippert Above Floor Slide out!
But our Schwintek slides will have to have the motors detached and in my opinion there is nothing to hold the slide-out when manually pushed in.
Old 04-16-2016, 05:55 PM   #15
OK sorry I answered "Both" of you Peoples Slide Q's! You were asking about Two tottaly diff slide assys and I answered both! I gave Proper Info.for the Unanswered Q's! I am glad you Thanked Josh though! Youroo!!
Old 04-16-2016, 09:55 PM   #16
Anyway, I am making up a pair of slide-out travel rods for the Schwintek just in case.
Using pipe donated by my neighbor (electrician) and the DW who has the rubber ends sitting in a drawer. Total cost 20 minutes time. Just have to cut to length tomorrow.
Old 04-17-2016, 12:48 AM   #17
benagi's Avatar
Ben, do you have rods? Mine are too short, I should make some just in case!
We do have rods. DW has our unit in Grand Jct. at a dog trial right now . Will have to check length when she gets back tomorrow.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 04-17-2016, 01:20 AM   #18
Kc2427, do you have rods?
I wonder if the OP Kc2427 received traveling rods?
Ben, curious to see what size rods you got with yours. I will post a photo of the correct ones tomorrow once I cut it with the ones they gave me.
Ben, that's GREAT that the DW drives the MH. Mine DW does also, from the potable water hose 30 ft straight to the dump station with me guiding her.
Old 04-17-2016, 10:06 AM   #19
Boso's Avatar
2 -2 by 4's cut to size Lowes or Home Depot will cut for you if you get in a bind on the schwintec slides
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 04-21-2016, 10:11 PM   #20
Found in the Schwintek manual page 8 that you may only need to unplug the motors from the controller and push the slide in with lots of help. Then reconnect the motors to the controller. Reconnecting the motors hold the slide in place. If necessary to unscrew motors, then traveling rods are needed to secure it.
http://www.rvtechlibrary.com/exterior/breezeslide.pdf
forester, manual, slide
