Old 04-11-2016, 03:06 AM   #1
Manual slide on forester 3011 2016
Can any one tell me how to manual slide in slide outs on my forester 3011 2016. I cannot figure out either slide. I don't want to be on a long road trip and get stuck because I can't figure out how to slide in my tip outs.
Kc2427 is offline   Reply With Quote
Old 04-11-2016, 06:17 AM   #2
Are your slide systems "Schwintek", if so there is a drive motors on each side that has to be "Disengaged" then the slide is "Pushed In Manually"! Unless they came up with a Easier way? Youroo!!
Old 04-11-2016, 04:23 PM   #3
Thanks for the info! Any idea on the front slide? Not even sure what type of slide?
Old 04-13-2016, 04:50 PM   #4
Class C Representative
Joshua Cavitt's Avatar
There is a set screw on the schwintek motors that would need taken out to disengage the motors. You can see it if you pull back the trim on either side.
The Lippert above floor slide in your living room has a nut head accessed from the storage compartment below. You can use a 5/8 Socket, Open ended wrench, or boxed wrench to bring the slide in and out manually.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 04-14-2016, 01:15 AM   #5
Thanks Joshua cavitt!
Old 04-14-2016, 01:42 AM   #6
Sagecoachdriver's Avatar
Joshua, once the slide(s) are in, must you install a traveling rod to secure it from moving? Mine came with 2 that are 20" long and both of my slides are much deeper than that.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 04-15-2016, 12:27 AM   #7
benagi's Avatar
Sage, I was told to only use the rods if the slide is broken or creeps on you. If everything is working properly, you shouldn't need them. Also, I have read that some who have used them in the past on a working slide and forgot to remove the rods, ended up damaging the motors when extending the slide.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 04-15-2016, 01:55 AM   #8
I was told the same thing that they weren't needed on on a daily basis as the motors keep it in. But does if you manually have to bring it in, do you need the rods. If I remove the motors on the bedroom Schwintek, what's to hold it in? The Lippert above floor system has the 5/8" nut to turn with a ratchet, will the motor still hold it in?
Old 04-15-2016, 11:29 PM   #9
benagi's Avatar
I know on the Schwintek slide if you disconnect the motors, you have to use the rods. On the lippert slide when you manually bring it in, I'm not sure either. Maybe someone else can answer the question for us.
1968 tent trailer
1985 Jamboree 23 ft
Old 04-16-2016, 01:46 AM   #10
Ben, do you have rods? Mine are too short, I should make some just in case!
forester, manual, slide
