Old 09-14-2018, 07:14 PM   #1
Marker light fuse
Anyone know where the fuse is located, that runs the the marker lights. I have a Forester 3011D
Thank you,
Dale
dcolby57 is offline   Reply With Quote
Old 09-15-2018, 01:30 AM   #2
The model year is a 2014
Old 09-15-2018, 11:37 AM   #3
Duckogram's Avatar
Your side marker lights and clearance lights run off of the chassis electrical. When you use your light setting on your dash switch or open a chassis door, they should come on. FR connects these lights so there should be a junction block under the dash if they did not use the Ford connector. I would look in the Ford owners manual for the location of your “parking light” fuse.
ILB ( | )
forester, fuse, light
