Old 07-20-2016, 03:54 AM   #11
CW has MaxxAir II for 46.49$ use that as a reference! Youroo!! These come with ALL the Hardware for Easy Install/Hinge Easy clean! 6 year Warr.also!
Old 07-20-2016, 07:57 AM   #12
WFD
Originally Posted by benagi View Post
Looking at installing a couple of MaxAir II's on our unit. Where's the best place to purchase them from?
Also check out Amazon..often have great prices with free shipping.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-20-2016, 04:08 PM   #14
WFD
Wth the Fantastic vent cover you will need to remove caulk and screws in your flashing and insert their screws and re-caulk. I wasn't prepared to do that so went with the Maxaire despite what this video shows...Our fans move ample air with the Maxaires, don't think they are restrictive at all. Although you see a difference in the damper in the video, I think it has minimal effect on ability to actually move air...not enough for me to re-caulk around the flashing in any case.
Old 07-21-2016, 12:12 AM   #15
benagi's Avatar
WFD, I like the idea of not having to remove caulk and screws. Think I will go with the MaxAir II for that reason.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-21-2016, 04:21 AM   #16
Witch Doctor's Avatar
Very smart try not to disturb that seal around the vent. Nobody wants a roof leak or worst getting a leak between the rubber membrane and plywood decking that will cause the wood to delaminate. Roofs are expensive to repair, I know mine just cost 5400.00 to do and a week of time at the factory.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-21-2016, 12:06 PM   #17
RETIRED
n-e-d's Avatar
Location: Home of the 5 time Super Bowl Champions Patriots. How do you like dem apples Rodger
Installed my Fantastic vent cover when I also installed a Maxxaire fan with remote over queen bed. Couldnt have taken more than an hour and tube and a half of Dicor. No leaks,even tho it was uncovered this winter
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
Old 08-08-2016, 10:26 AM   #18
vwexpert's Avatar
I decided to go with the Fantastic covers. It was very easy - 1/2 hour to install 3 covers. The small amount of caulk that is removed does not effect the sealing of the vent. A little goop in the screw hole / edge of vent / install the brackets / and then a little goop on the top off the new screw.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
cover, fan, vent
