Old 02-03-2016, 12:27 PM   #21
Fulltime family RVer
Originally Posted by newRVer View Post
Where does one get their RV weighed? I was thinking about doing that now since it is brand new and I have nothing it at this point except what was delivered with the RV.
RVr
Sagecoachdriver is right. I've never seen prices that low (it's typically been $10-12 for me).
Otherwise, if you happen to be near any of the Escapees SmartWeigh locations- I strongly recommend doing that. The big difference is you get individual wheel weights this way. Coaches are rarely balanced on either side.
https://www.escapees.com/knowledge/smartweigh
ependydad is online now   Reply With Quote
Old 02-03-2016, 01:20 PM   #22
Looks like there is a CAT Scale only 5 miles from our House. I will have to run it up there when I have a chance to see what it weighs with a full tank of GAS.
newRVer is offline   Reply With Quote
Old 02-03-2016, 02:22 PM   #23
Creativepart's Avatar
Originally Posted by Sagecoachdriver View Post
Cost $7 but it only give you the front, rear and total axle weight. Doesn't do individual wheel weight.
On no Sage, it will give you individual wheel weights. All of these Cat scales have 3 weight sections. And while the front section has a couple of pillars and signage over it the two back sections don't and each have an apron on the sides of about 2 feet wide.
So, you don't pull up to the front weight section. You use the two back scale sections and pull up with two wheels on one side of the RV completely on the apron (not the scale) and two wheels on the other side on the two scale sections. Get a weight recorded and then reposition on the scale with the wheels on the other side on the apron and the two other axles on the scale.
You'll end up with two weight readings - usually $7 to $10 for the first and $2 or $3 for the second - and the numbers shown on the print out will be the individual axle weights of each side of the RV.
I also put the whole RV on the scale and got a complete weight too. The individual Axle weights I got added up to the total weight so I knew the apron method worked just fine.
You can find a Cat Scale at most Truck Stops, like Pilot, Flying J, or Loves.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 02-03-2016, 02:37 PM   #24
Here's what a Cat Scale looks like with the apron on the sides that I mentioned. And before that is photo that illustrates the one side on and one side off method of positioning on the scale (It's a hwy truck scale but you get the idea).
Old 02-09-2016, 08:53 PM   #25
Garrette's Avatar
There is a great article in a last issue of Motorhome mag about how to weigh and get individual tire weights.
Garrette is offline   Reply With Quote
Old 02-10-2016, 08:35 AM   #26
Citrus County, Fl.
GL1800Rider's Avatar
I have only got the all 4 together and rear only weighed so far. Our land fill does it free as long as you don't need it certified. At least it told me what my total loaded weight was loaded for traveling with full full, empty holding tanks and 1/3 tank of water and also what I had on each axle. If would be nice to know what is on each wheel though.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 02-11-2016, 12:10 PM   #27
Sagecoachdriver's Avatar
CreativePart, did you resolve the clearance light lens issue? Could this be it, or are yours orange?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-11-2016, 12:15 PM   #28
Nope, that's not it and I did not solve this. In fact, it seems the only long term solution would be to replace all 5 of the lights. The company went out of business and I've found no supplier that has them in Amber. There are some out there in Red, so I've installed the Red ones on the two outside positions. So, now my clearance lights are Red - Amber - Amber - Amber - Red.
No doubt this is not proper and may not be legal - but it's a small thing and no one will notice.
When I added the Red covers I siliconed ALL 5 of the lenses to try to keep them in place.
Old 02-11-2016, 02:03 PM   #29
Steeljag's Avatar
GL - were you good with your weights on the 3011 ? Decent amount of CCC remaining ?
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 02-12-2016, 10:53 AM   #30
Originally Posted by Creativepart View Post
3. Winegard Pathway X1 Satellite Dish (roof mounted)
We've had a Winegard automatic sat dish for 3 or 4 years - but its the kind you carry out, run a coax cable to, run 12-volt DC to it and place it on a stand in your campsite. It's great and always works, but it's a big hassle to do all that - so much that you just skip it for shorter stays. I really splurged and picked up a smaller, newer, easier Sat dish and mounted it on the roof. The difference is you just turn on your receiver, select the State you are in and boom - you've got your Dish Network channels. No muss, no fuss. So, for overnight stops it's just as easy as using the regular TV Antenna. We still carried our older "portable" dish as a back up - and actually found it to come in handy once. But the roof mount came in handy at all other stops.
Following your lead and purchased the Winegard Pathway X1 dish. Will try it out over the next few trips before deciding on the roof mount or keeping it portable. Not buying the window mount yet either as no sense if we roof mount it. Maybe the ladder mount will be back out by then. Going to test it this morning.
Thanks, oh did you do the mounting yourself? Saw the mounting brackets at CW.
cat, modifications
