06-14-2017, 11:07 PM
More 2017 Forester 3171DS questions…
Where can I find the WIFI password for the control pad?
To watch tv through cable, do I need to unplug the antenna coax and plug in the cable coax? (In the cabinet below the stereo.)
Can the tv audio be played through the house speakers?
06-15-2017, 07:35 AM
Retired and Loving Life!
The passcode to the wifi for the control pad is on a sticker on the back of the cabinet over my kitchen sink. It is not a large sticker, but it has a hand written password on it. I had to search for it, but eventually found it there.
To watch tv through cable, you will need to use the tv remote. Go to input, and indicate antenna or cable. It gives you the options. Use the one you wish to use. You do not need to unplug anything. This goes for all the televisions. Use remote/menu/input
According to several threads on here, in order to utilize the house speakers, you will need to purchase an rca cord and hook from the tv output to the radio input to get it to work. Mine doesn't work either, but that has not make it to my "to do" list yet.
Happy camping!
06-15-2017, 07:38 AM
Also, when watching cable, make sure your antenna booster is turned off. If left on, your cable picture will be snowy. The switch on mine is in the left hand cabinet over the dinette.
06-15-2017, 08:21 AM
TV audio through speakers.
In my Forester, the TV audio will play through the in house speakers by changing the Mode on the radio/DVD player. I'm not in my camper but I believe it is HDMI ARC. Once selected, it takes a few seconds for the sound to switch to the speakers. Hope this helps.
06-15-2017, 08:59 AM
Same with my house speakers !
On mine this only works by turning the radio on first - HDMI ARC.
Then TV on, and it takes a few seconds for the sound of the house speakers to come on.
Tablet code on ours is also located on a sticker in kitchen cabinet.
Good luck !
1930 lbs CCC
2014 Jeep Rubicon JK
06-15-2017, 03:07 PM
So does this mean that the radio must be left on while watching tv with tv audio going thru the ceiling speakers???
Which radio/dvd unit are you fellas using?
Walter & Anne
2013 Forest River Sun Seeker 3100SS
06-15-2017, 04:06 PM
Yes, power to radio is on.
Mine is the Jensen system.
1930 lbs CCC
06-15-2017, 09:28 PM
Good luck !
I have the same system and the Jensen Radio. The HDMI ARC setting works for the DVD player. I get both the. Idea on the TV and the sound through the House/ceiling speakers. However, I cannot get the tv to play through the house/ceiling speakers. I set it to the HDMI ARC setting and all I get through the speakers is a hum. I tried turning the radio on first, and then the television, but zippo. Nada. Only the tv speakers work. Am I missing something?
06-16-2017, 08:04 AM
Alan - That is all I do for the TV to work with both inside, and outside stereo speakers!
Just reading all the posts the last few months on this topic, it seems these things are wired at the factory in a dozen different ways !
Hope you can get it working !
1930 lbs CCC
07-11-2017, 01:08 PM
I found the code! I had to remove the back panal in the cabinet above the refrigerator and there it was. (The generator genie is also there. )
Waukesha, WI
07-17-2017, 10:45 PM
Generator genie
What is a generator genie?
07-17-2017, 10:49 PM
Try switching the HDMI cable into the other HDMI socket on the TV.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
07-18-2017, 12:58 AM
It's a control box that allows the MyRV system to control your generator from the tablet or a smart phone.
Everything MyRV has a little electronic box that communicates with the connected devices.
Kirk
2017 Forester 3051S
07-18-2017, 08:59 AM
(If yours is stuck on 17 hours, it is defective and will be replaced under warranty.)
Waukesha, WI
