Old 04-20-2016, 08:41 PM   #91
sgtlm17's Avatar
Installed a simple voltmeter next to my converter. It is wired directly to the batteries with an in line fuse. Nothing fancy.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 04-24-2016, 05:05 PM   #92
sgtlm17's Avatar
I have the coffee pot on the counter next to the stove. The outlet is underneath the overhead cabinet but towards the front. This made leaving the coffee pot plugged in difficult cause the wire was just hanging. I installed an additional outlet towards the back of the overhead cabinet. Now the cord for the coffee pot is out of the way. Yes I'm a little obsessive about wires and it looking clean. While I had the tools out and cabinet opened I installed a 12v blue led nightlight.
ID:	105951   Click image for larger version
Old 04-26-2016, 02:08 PM   #93
RedLdr1's Avatar
Keep the mods coming! Our GTS is being built next week so it is only about a month to go before it arrives and the mods begin...
How do you keep the outside accessible trash can from sliding around in the compartment? The one photo I've seen has a lot of wasted space around a fairly small garbage can. It looked like it would be way too easy for the container to slide away from the "drop zone"... I'm thinking the box of trash bags, and some other outside stuff, will go in that compartment to help with any shifting issues.
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 04-26-2016, 03:11 PM   #94
Not had a problem with the trash can.
AbdRahim is offline   Reply With Quote
Old 04-26-2016, 03:27 PM   #95
sgtlm17's Avatar
I concur trash can doesn't move around. Fits perfect.
Old 04-26-2016, 03:34 PM   #96
RedLdr1's Avatar
Hmm, maybe that trash can was a "dealer installed" option. It looked waaaay too small for the compartment. I'm glad it isn't a problem as it could get messy quick...
Wayne
Old 05-03-2016, 02:37 PM   #97
RedLdr1's Avatar
Okay, our unit is on the line this week and in paint next week so I'm getting closer. So I'm going through tweaking my old PDI check list and a big one is air pressures in the tires and now suspension air pressures. What tire pressures are you running front and rear? And what are you guys running on the air bags? Do you "set and forget" the air suspension or are you adjusting them for load?
I'm considering adding an on board air compressor to be able to adjust the suspension "on the fly" and to have a easily accessible compressed air source. Anyone done that mod yet?
Thanks,
Wayne
Old 05-05-2016, 12:01 PM   #98
Tombsy's Avatar
I keep extra rolls of paper towels, there is just room for two in mine.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is online now   Reply With Quote
Old 05-12-2016, 10:59 PM   #99
sgtlm17's Avatar
I installed the Camco extend a stay on the propane tank. . I used a small piece of aluminum to extend the bottom under the regulator. Super easy took 10 minutes.
Old 05-13-2016, 08:00 AM   #100
Tombsy's Avatar
Nice, I got to try mine out last trip after using the furnace for two weeks. I picked up a bottle and it kept us going the last few days.
Brian
Brian
280, modifications
