Old 05-31-2016, 08:05 PM   #111
RedLdr1's Avatar
We do our PDI tomorrow morning and hopefully will bring our GTS home in the afternoon. I've got my eleven page PDI checklist printed and ready to go along with the tools and various gauges, meters, and test sets I'll need. Anyone have anything in particular to closely check on the GTS?
Wayne and Christine
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium
RedLdr1 is online now   Reply With Quote
Old 05-31-2016, 08:10 PM   #112
sgtlm17's Avatar
Just from what I've read here that the new units come with a plastic toilet. If that's true and it matters to you see if you can convince them to change it out
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 05-31-2016, 08:21 PM   #113
RedLdr1's Avatar
It is true and my dealer agreed to swap it out for the previously standard Dometic 310 unit. Now I just need to get one of those fancy seats...
Wayne and Christine
Old 05-31-2016, 08:31 PM   #114
sgtlm17's Avatar
Yes you will have a great toilet and the cheapest thinnest seat known to mankind. Lol the enamel wood is great
Old 05-31-2016, 08:32 PM   #115
You may want to keep an eye on the storage compartments underneath. Mine were pulling away from the body of the coach. Unfortunately next to the fresh water tank, the wide gap was just filled with silicone. Not nearly enough screws to hold against that tension.
AbdRahim is offline   Reply With Quote
Old 05-31-2016, 09:46 PM   #116
Tombsy's Avatar
I just got back from two weeks fishing at a remote campsite with no services. Everything went great but I have a problem for the wiring pro's, I used a small inverter in the 12v outlet in the bedroom and plugged the bedroom tv into that. (For some reason my main tv is 12v but the bedroom is 110v) It worked fine until it didn't, now the outlet is dead and I can't find a fuse for it. Everything else is working, I pulled the outlet and there is definitely no power to it or any sign of an inline fuse. Any ideas?
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is offline   Reply With Quote
Old 06-01-2016, 04:12 PM   #117
RedLdr1's Avatar
I've seen 12VDC outlets fail from over heating. Testing for power with a multimeter at the wiring on the back of the outlet would be my next step.
Wayne and Christine
Old 06-01-2016, 04:38 PM   #118
RedLdr1's Avatar
Great PDI today... The MBS took almost seven hours to do, fixing issues as they were uncovered, while the GTS only took two hours to go through the same basic PDI list.
The only items found were:
Paint Damage and Issues: As I mentioned earlier there is shipping damage on the rear bumper and rear cargo hatch, and the front right fender has a sagging run in the paint.
The rear TV is toast. First, the remote control doesn't work, second the unit will not accept a DVD. BTW this is a 12VDC TV not a 115VAC powered one... New TV on order.
Jensen Entertainment Center. The unit would not accept a CD or DVD. Turned out there is a shipping screw that someone didn't remove when installing the unit. The warranty coordinator had seen that one before so it was a quick fix when he came out to check out the unit.
The PDI tech had discovered the AC power wasn't properly wired. The unit ran on shore power but the generator set wasn't connected to the transfer switch. He had corrected that before we arrived today.
That was it for PDI issues. Half hour doing paperwork after the PDI and we now have our new GTS!
A couple observations:
I found out the water pump has an inline fuse next to the pump in the water compartment. Are there any other in line fuses anyone is aware of?
My DW is in love with the optional recliners and their little snack tables...
I really like the "Auto" leveling system... I won't be without that little toy ever again!
Overall today was a much better "First" day than we had with our MBS...
Wayne and Christine
Old 06-01-2016, 06:28 PM   #119
Creativepart's Avatar
Some notes on that bedroom tv - it will not accept a DVD unless you set the source to DVD. Of course if your remote is not working it would be difficult to change the source. There are buttons on the top of the TV and you could do it from those. But how are you going to see those to know which ones to push.
ALL three of the TVs in my coach are 12-volt.
2015 Forester 3051S
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 06-01-2016, 07:00 PM   #120
Tombsy's Avatar
Thanks, I pulled out the outlet and there is no power at the back that's why I'm wondering if there is an inline fuse somewhere, I couldn't find anything in the wall.
Brian
Brian
280, modifications
