Old 06-30-2016, 07:51 PM   #141
Tombsy's Avatar
I've sure seen a lot that do but we bought ours with 5000 miles on it and someone else ordered the options I guess. But the good thing is all the bugs seem to be out and we haven't had any problems or warranty work.
Brian
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is offline   Reply With Quote
Old 06-30-2016, 08:46 PM   #142
RedLdr1's Avatar
Originally Posted by AbdRahim View Post
Yikes, Brian. I guess I lucked out. Thought the 2801 came with the leveling system.
They are a $2,993 (MSRP) option on the Sunseeker... I always get a laugh out watching ours level the coach. They remind me of an old Cheech and Chong routine of a low rider bouncing around at a stop light...
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 06-30-2016, 11:48 PM   #143
Brian
Well, hoped I was through the bugs, but my passenger side camera died on the way home today. Warranty expired two months ago.
AbdRahim is offline   Reply With Quote
Old 07-01-2016, 09:51 AM   #144
Tombsy's Avatar
Uh oh I don't have side cameras either
Brian
Brian
Old 07-01-2016, 11:35 PM   #145
More 2801 mods
Less to fix. 😎
Old 07-02-2016, 06:23 PM   #146
Tombsy's Avatar
Originally Posted by RedLdr1 View Post
My next step would to be to put a tracer tone on the cable and see where I could find it next. You'll need a Toner / Tracer like the one shown Here to do that. Make sure the 12VDC power is off when you are tracing the wires. The Tone Generator can do a very good job appearing as a a short and blowing fuses! The Tone should appear at one of the two 12VDC fuse blocks unless there is a blown in line fuse or bad wiring.
I purchased the tone generator and worked on tracing it out today. Nothing at the fuse block but really strong around the bathroom lights. Bingo the outlet is wired to the bathroom light switch, it works fine when the lights are turned on. I'll be fixing that Lol.
Turns out the bedroom tv is 12v as well, it was plugged into 110 with a 12v adapter I just need the Furrian cord for 12v.
I tapped into the power at the light switch in the front cupboard for the Alpha wifi booster so I didn't need to take up a 12v outlet for it.
Brian
Brian
Old 07-02-2016, 07:16 PM   #147
RedLdr1's Avatar
I'm glad the toner set found the issue for you. Someone screwed that up royally as our GTS is not wired like yours....
Wayne
Old 07-08-2016, 01:20 PM   #148
Found some old chair slides in the basement so I used them to eliminate the screeching sound the bed makes when the slide goes in/out due to wood on wood contact when sliding.
newRVer is offline   Reply With Quote
Old 07-08-2016, 05:28 PM   #149
Tombsy's Avatar
Looks good but my bed doesn't look like that at all I'll have to check it out.
I installed the Levelmate Pro in the centre of the front cabinet, pretty slick, I levelled the rig for a baseline and entered the wheelbase measurements. Now I via Bluetooth my phone shows in inches how much blocking I need under the wheels.
Brian
Brian
Old 07-08-2016, 07:06 PM   #150
sgtlm17's Avatar
Looks pretty cool Brian. I'm sure you've tested it a few times. Is it accurate. I would love to get this for one of my next mods.
Lou
2016 Forester GTS 2801QSF
RVHabit.com
sgtlm17 is offline   Reply With Quote
280, modifications
