Old 08-30-2016, 12:28 AM   #171
Not much carrying capacity. With my wife and I in the bed I am essentially maxed on the rear GAWR, with full fresh water tank and not much gear.
AbdRahim is offline   Reply With Quote
Old 09-21-2016, 04:30 PM   #172
RedLdr1's Avatar
Today I had new one piece steel valve stems installed in the rear duals. These are from duallyvalve.com Part Number DL1FC. I had a set of these on our MBS and they solved both the slow leak and mounting a TPMS sensor issues. I have a TST 507 Flow Thru system I haven't reinstalled yet. And I need to dig out the hubcaps as well....
GTS Valve Extenders
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 09-21-2016, 10:08 PM   #173
Thanks I need to do this.
Old 09-22-2016, 06:33 AM   #174
GTS Valve Extenders
Around how much did that cost if I might ask to have the valves stems installed? Adding TPMS might be a 2017 option for us.
newRVer is offline   Reply With Quote
Old 09-22-2016, 08:50 AM   #175
RedLdr1's Avatar
$64.00, with tax and fees, to install the new stems and do a balance on the rear four rear wheels. This is around a $200.00 project. But after dealing with slow leaks, not being able to air up a tire, or mount a TPMS sensor on the OEM junk extenders it was well worth it to me....
Wayne
Old 09-22-2016, 09:05 AM   #176
Sagecoachdriver's Avatar
Did you have to enlarge the holes on the stainless steel wheel covers? I had to on my old Winnebago, as the J valve prevented mounting it.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 2 trips 5 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-22-2016, 09:29 AM   #177
RedLdr1's Avatar
Yes, I'd already enlarged the holes on the covers. I originally had "cap style" TST TPMS sensors. They would not even begin to fit without cutting the covers. While at the F.R.O.G. Rally I "upgraded" to a new TST system, with flow thru style sensors, which might have fit without any cutting.
Wayne
Old 09-24-2016, 07:52 PM   #178
sgtlm17's Avatar
A totally unexpected mod today. Cleaning my workshop and I came across a "White Night" light that I purchased about 8 years ago. Still in it's box never used. It is a light that mounts to the 2 inch hitch receiver and gives you two 55 watt halogen lights when backing up. The center has a removable cap which still allows use of the hitch.
Now not wanting it to go to waste I decided to put it on the RV. It's a simple 3 wire installation that uses a ground, a 12v power and the reverse light wire. It has a switch on the back that lets you put it on manually, turn it completely off or auto mode which allows the lights to come on when the RV is in reverse. I'm sure it will help when backing at night.
2016 Forester GTS 2801QSF
ID:	121179   Click image for larger version
ID:	121180   Click image for larger version
ID:	121181   Click image for larger version
sgtlm17 is offline   Reply With Quote
Old 09-24-2016, 07:59 PM   #179
RedLdr1's Avatar
Nice, I could use that! Did you use the wiring to the 7 pin connector to hook it up or tap in to the existing lights?
Wayne
Old 09-24-2016, 08:01 PM   #180
That's pretty neat, but they must be out of business. Their website shows something totally different.
They do still show up on the internet, though if someone wants to buy one:
https://www.google.com/webhp?sourcei...ackup%20lights
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
280, modifications
