Old 08-03-2017, 05:27 PM   #361
sgtlm17's Avatar
Originally Posted by Tombsy View Post
I've finally been working on this Airlift Wirelessone for the airbags that I've had for awhile. I've been procrastinating getting under my rig and doing it partly because I don't have a great place to do it aside from the dirt storage lot and partly because wiring isn't really my forte lol.
But I mounted everything on a piece of ply and wired it up including an extra relay and I'm hoping to mount it in the bay where the water pump compartment is. I have a switch for it if I use the coach batteries or I can go to a switched ignition source, haven't decided yet. Just have to suck it up now and get under there and do it. [emoji12]
Attachment 146987
Let me know how it works out. This is on my mod/upgrade list.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 08-04-2017, 11:08 AM   #362
You are a brave man Tomsby. For me, I would need to call a professional for that.
AbdRahim is offline   Reply With Quote
Old 08-04-2017, 11:25 AM   #363
Tombsy's Avatar
Lol I have found a place that can do it, but I figured I can at least get the components mounted. Then I was pretty confident I had the wiring with the extra relay figured out and it works on a test battery. The actual spicing into the airlines should be pretty easy (famous last words) two cuts with three tees. So I guess we'll see when I actually get under the rig. But checking and filling those bags is such a pain it keeps me motivated.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 08-04-2017, 02:59 PM   #364
I agree on the pain. I often thought it would be nice to just push a button like the big rigs. I will be watching to see how well it works.
Old 09-07-2017, 10:50 PM   #365
Tombsy's Avatar
Well I spent the last couple days on my back under the rig and got the Airlift One compressor installed. I ended up putting it in the back of the long compartment on the drivers side. I ran the wiring to the coach batteries with a relay to a switch mounted above the battery cutoff and I ran all the wiring and airlines in cable sheaths the same as the factory.
The install works with no leaks but it turns out the manifold is not communicating with the remote to set the air pressure so the compressor won't shut off. I talked to customer service to trouble shoot it and they are sending me a new manifold.
But here are some pics of the install.Click image for larger version
ID:	150929Click image for larger version
ID:	150931Click image for larger version
Brian
Old 09-10-2017, 08:12 PM   #366
I guess that is one I will leave to the professionals. That is way above my pay grade.[emoji41] Looks good.
Old 09-27-2017, 10:48 PM   #367
Tombsy's Avatar
Success! After scratching my head for awhile looking at the wiring schematics I realized I had a wire hooked up wrong and now everything is working perfectly. Wireless control for the airbags finally. We have a big trip coming up in a few weeks, Calgary to Las Vegas and I can’t trust the weather until then so I winterized while I was there too.
Last thing was a wireless camera mounted above the hitch that works with the Garmin GPS. The main backup camera is aimed high to see the toad and behind.
Brian
Old 09-28-2017, 12:24 AM   #368
What kind of camera? How good is the image? Doesn't' it get dirty often? Is that on the TV or on the MH?
Old 09-28-2017, 07:55 AM   #369
Tombsy's Avatar
It’s on the motorhome just above the hitch, the camera is the Garmin bc30 and is compatible with my rv660 gps. (Plus a list of others). The picture seemed pretty good, we’ll see how dirty it gets but pretty easy to give it a wipe before using it to hitch up the toad.
Brian
Old 12-15-2017, 04:35 PM   #370
Originally Posted by sgtlm17 View Post
I did these mods last week.
TRC SurgeGuard with remote.
Sirius XM docking stations for cab and coach.
Blue LED lights with switch for doghouse cup holder area.
Screen door bar.
How did you route the wires to the back of the surge guard display?
Old 01-06-2018, 11:07 AM   #371
sgtlm17's Avatar
Ran wire up where water heater sits then over to the step into bed area. That front step pulls off. Across the step into area under fridge which is all open. Then installed display in wall on side of fridge.
2011 Jeep JK Toad
Old 01-06-2018, 04:21 PM   #372
Thanks, I wondered if there was a way o access under that step. It looked like it was screwed to the upper floor. How is it attached at the kitchen level? Btw, hope you all had a great holiday season. 4 1/2 months to spring.
Old 01-06-2018, 04:30 PM   #373
sgtlm17's Avatar
I removed the metal corner molding (it is screwed it) then the front piece is wood and has a few small nails. It easily pulls off.
2011 Jeep JK Toad
Old 01-13-2018, 11:32 PM   #374
I just went through the thread from the beginning and found it interesting that no one mentioned replacing the jackknife couch. I like the storage underneath it, but it is hard on the sitting apparatus. I am planning on checking out alternatives this spring. Hopefully, I will find a place that has what I like in stock somI can sit on it and see how it feels, then have it installed. It would also remove access to the subwoofer underneath. I did add the swivel mechanism for the passenger seat. It is the most comfortable set in the MH.
Old 01-14-2018, 01:28 AM   #375
sgtlm17's Avatar
Yes I knew I couldn't sit on that couch for one minute. I got the theater seating even though I lost a sleeping area
2011 Jeep JK Toad
Old 01-14-2018, 01:57 AM   #376
Tombsy's Avatar
Me too it’s definitely on the list, I’ve been keeping an eye on what others have been using to it. For now a couple collapsible footstools help.
Brian
Old 01-27-2018, 12:42 PM   #377
Tombsy's Avatar
Well I took the wife to the RV show for her birthday last night , one of the dealers carries RV furniture locally and we got a deal on a pair of recliners with heat and massage. Yahoo! can’t wait to get rid of that couch, maybe I’ll try to get a couple bucks for it on Craigslist.
Brian
Old 01-27-2018, 01:23 PM   #378
sgtlm17's Avatar
Oh that would be nice if my recliners had heat and massage
2011 Jeep JK Toad
Old 01-27-2018, 07:17 PM   #379
Tombsy's Avatar
Sgtim17 where’s your subwoofer?, might have to relocate it.
Brian
Old 01-27-2018, 07:25 PM   #380
sgtlm17's Avatar
The subwoofer is behind the recliner closest to the front of the rig.
2011 Jeep JK Toad
280, forester, modifications
