Old 04-01-2016, 11:38 PM   #41
Tombsy's Avatar
Beautiful 70 degree day in Calgary today, spring is coming pretty early. All the easy mods today . Installed the new shower head, valve extenders on the duallies for the TPM sensors, a new set of AGM batteries, and put in the tune from 5 Star. Most of my driving will be thru the Rockies and we're at 4000' so hoping it will help out.
And most important my fear no fish license plate.
Brian
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is online now   Reply With Quote
Old 04-02-2016, 10:25 AM   #42
Brian
Not so hot here in central Wisconsin. Woke up to this this morning.
Name:	Spring in Wisconsin.jpg
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 04-07-2016, 07:36 PM   #43
sgtlm17's Avatar
Got my Camp Pro WiFi booster kit yesterday and did the install today. It comes with an Alpha Booster Tube, Alpha antenna and an Alpha R36 router, plus everything else you need to complete the install. I got it from Rokland.com and there customer service is great. Price can't be beat at $100.00. I've seen this priced separately for over $200.00 and similar devices at $400.00 or more.
With the 2801 came some challenges of where to mount the booster tube and antenna. The recommended spots are the RV ladder or batwing TV antenna. I have neither on the 2801 so I used the rear vent cover and it worked out perfectly. I mounted the antenna horizontally as to keep the height of my rig under 11 feet. I routed the USB included wire from antenna to the fridge vent which leads right into my electronics cabinet above my door. The router is in this cabinet and fits perfectly. I used the included 12v power cord in lieu of 110v so it can be used when off grid.
Setup is easy with any phone, tablet or laptop. A big plus not needing a laptop to configure. You sign in pick a Hotspot or network and click apply and your done! I went from seeing only my home network on my phone to the Alpha R36 seeing 18 available networks. It shows signal strength of each available network and type of security. Have only tested it from home but so far I give it two thumbs up. Super easy upgrade/mod.
2016 Forester GTS 2801QSF
ID:	104207   Click image for larger version
ID:	104208   Click image for larger version
ID:	104209   Click image for larger version
sgtlm17 is offline   Reply With Quote
Old 04-08-2016, 02:06 PM   #44
SGT,
I have been looking at wifi options for my new RV and your post caught my eye. I'll have to do some more research on this unit but the price certainly is right. Two questions though. One - since you have the antenna horizontal instead of vertical, have you noticed any limitations for accessing different points? The reason I ask is because Omnipole antenna's typically work best when placed vertically because of the radiation pattern of a pole antenna. That is, unless you know the direction of the source wifi your trying to repeat and you can orient the direction of the RV accordingly. Also, do you have to plug in to the ethernet port to change the wifi point your are trying to connect to or can you do that wirelessly?
RVr
newRVer is offline   Reply With Quote
Old 04-08-2016, 02:28 PM   #45
sgtlm17's Avatar
You are correct vertically is the optimum way to install the antenna. I chose this horizontal install to keep max height of rig the same as it was. I live in the country and can only see my homes wireless access point on my tablet and phone. Today I checked with the CampPro and 26 wireless access points were visible so I know the antenna is reaching out. I like this system as you do not need to connect via hardwire to change the WiFi point. They recommend hardwire for first time setup which I did. Now I just use my phone and connect to the router and pick any WiFi point I want and hit apply. You can see a video by TechnoRV on you tube. They sell this system as separate units. Good video of how it works. Once you set up a name for your router and a password you never have to change that. Your only picking an available Hotspot or available network. I have not tested on a free network where you have to agree to terms on a Web page like many campgrounds do.
Old 04-09-2016, 08:11 PM   #46
Added shelves to the right side of the bedroom closet.
Name:	ImageUploadedByForest River Forums1460247059.187755.jpg
AbdRahim is offline   Reply With Quote
Old 04-09-2016, 08:34 PM   #47
sgtlm17's Avatar
I plan on adding shelves there also. I can't decide whether to use wood or the white metal ones they sell at Lowe's. Looks great.
Old 04-09-2016, 09:14 PM   #48
Should have used real wood.Cost would have probably been the same. .tis is laminated Closetmaid Shelf from HD. It just happened to be close enough to the right size (13" X 48").
Old 04-09-2016, 09:16 PM   #49
sgtlm17's Avatar
Matches well and has a finish on it. I think the laminated will be good
Old 04-09-2016, 09:45 PM   #50
Tombsy's Avatar
Looks really good, I'm still trying to figure out what I'm going to do under the sink it's a mess. Pots, frying pans, toaster, and the Keureg while travelling.
Brian
Brian
280, modifications
