Old 04-16-2016, 04:43 PM   #81
Check you storage compartments. Had separations from the wall in multiple compartments. The compartment with the fresh water tank has a 1/2 inch or more separation. .the gasket does not even touch the wall. ?Sealed with black silicone as directed by body shop. I wonder if sooner or later the tank will have to be removed in order to add more screws.There ar no screws from the compartment door all the way to the front of the compartment and up to the top, behind the rear tire.
AbdRahim is offline   Reply With Quote
Old 04-18-2016, 02:30 PM   #82
Originally Posted by sgtlm17 View Post
Oh and I installed a shower caddy soap dispenser.
That caddy looks nice. By chance does it also have a battery operated light?
newRVer is online now   Reply With Quote
Old 04-18-2016, 02:47 PM   #83
sgtlm17's Avatar
Now that would be nice but no it doesn't have a light.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 04-19-2016, 07:32 AM   #84
Too bad. Now I guess I have to install a caddy and a light! Although, if I though of it, it probably already exists on Amazon somewhere.
Old 04-19-2016, 09:04 AM   #85
sgtlm17's Avatar
Amazon is our friend. 😁
Old 04-19-2016, 10:39 AM   #86
Not sure I want to know, but why a light? Doesn't your bathroom already have lights?
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-19-2016, 10:51 AM   #87
sgtlm17's Avatar
Only a skylight in the shower. If it's real cloudy or dark out of can be tough to see
Old 04-19-2016, 03:15 PM   #88
Agreed!
Old 04-19-2016, 03:18 PM   #89
Also, I guess depending on the model you have, the shower could be in the bathroom where interior lights might be sufficient. In our 3011, the shower is across the isle and the interior lights do not allow enough light to filter through the glass shower door.
Old 04-19-2016, 03:27 PM   #90
RedLdr1's Avatar
The shower is in the bedroom on the 2800/2801 floor plans....
Name:	2800QS Floor plan.jpg
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
280, modifications
