Great PDI today... The MBS took almost seven hours to do, fixing issues as they were uncovered, while the GTS only took two hours to go through the same basic PDI list.
The only items found were:
Paint Damage and Issues: As I mentioned earlier there is shipping damage on the rear bumper and rear cargo hatch, and the front right fender has a sagging run in the paint.
The rear TV is toast. First, the remote control doesn't work, second the unit will not accept a DVD. BTW this is a 12VDC TV not a 115VAC powered one... New TV on order.
Jensen Entertainment Center. The unit would not accept a CD or DVD. Turned out there is a shipping screw that someone didn't remove when installing the unit. The warranty coordinator had seen that one before so it was a quick fix when he came out to check out the unit.
The PDI tech had discovered the AC power wasn't properly wired. The unit ran on shore power but the generator set wasn't connected to the transfer switch. He had corrected that before we arrived today.
That was it for PDI issues. Half hour doing paperwork after the PDI and we now have our new GTS!
A couple observations:
I found out the water pump has an inline fuse next to the pump in the water compartment. Are there any other in line fuses anyone is aware of?
My DW is in love with the optional recliners and their little snack tables...
I really like the "Auto" leveling system...
I won't be without that little toy
ever again!
Overall today was a much better "First" day than we had with our MBS...
