Old 08-22-2015, 08:31 AM   #1
More questions
1. If I carry an external propane tank how do I connect it to the onboard tank once I reach a campground and need extra propane? I plan on using the onboard tank while driving to cool the coach and run the fridge but once at campground run an external tank to save on the main tank. Either this or carry my two Honda gennys and Berg fuel tank and run off of them -if I can find room to carry them.
2. I would need the 15k A/C and I see it has a heat pump. Does the heat pump have auxillary heat strips or it just a heat pump (A/C that runs in reverse)
3. Is the one piece end cap an option on both the Forester and Sunseeker?
4. I am still confused on the three brands- Forester, Solera and Sunseeker. So Forester is top of the line? Solera was top of the line and is going away merging with Sunseeker?
5. Does both the 2400R and 2400W have fantastic fans?
6. Where are the physical locations of the A/C and fans on the 2400R and 2400W. What I mean is, is the a/c towards the middle of the coach, front, back, etc- same for fan. Why I ask is i may need to install a second a/c where the fan goes
7. Any place that I can find the external dimensions of the outside compartments for the 2400W and 2400R?
8. Is there a bike rack option? My current Columbus 295RL and previous Surveyor Select 264 had fold down bike racks that I could carry my genny's or extra propane on. If not I guess I could find a rack to fit into the receiver hitch
Thanks again
camperboy is offline   Reply With Quote
Old 08-22-2015, 12:34 PM   #2
RedLdr1's Avatar
Most of the MBS info is located in the Solera forum. There is very little MBS info in the Forester and Sunseeker forums. If you go to the Solera forum and do a search in it you'll find a lot of info. Anyway here is what I can answer....
3. It's standard across the MBS line I believe...
4. See Here.
5. Yes but be careful... The Forester comes with the 7350. The Sunseeker Fantastic Fan "upgrade" is for a 1250. If you go with a Sunseeker save your money and let the dealer install a 7350.
6. Go Here and look at the 2400W roof.pdf for a layout of the "W" MBS versions. The optional Fantastic Fan is in the living room, or the first position. Then the A/C then the bedroom fan and last the bathroom fan is the offset position.
7. For the "W" go Here and watch the video in the first post. Brian calls out all the external storage dimensions. You'll have to search for the "R"...
8. A bike rack is not a factory option I'm aware of...
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 08-22-2015, 02:11 PM   #3
4. See Here.
Thank You
Old 08-22-2015, 02:15 PM   #4
Class C Representative
Joshua Cavitt's Avatar
Solera is no more. We now build a Sunseeker and Forester MBS (Mercedes Benz Sprinter).
1. If you could run a line into the other propane tank or an auxiliary port in the lines somewhere. As for the Fridge you don't have to run it off Propane. Most of our coach is 12v compatible so you can run your fridge off of 12v electricity.
2. The heat pump does not have auxiliary heat strips, it is just a heat pump.
8. We do not offer a bike rack as an option.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 08-22-2015, 03:28 PM   #5
Thanks for answering my questions on a weekend.
Old 08-22-2015, 03:32 PM   #6
No problem. I'm available anytime!
Sent from my SM-G900V using Tapatalk
Old 08-22-2015, 03:54 PM   #7
Farkasb's Avatar
What type of privacy curtain/screen/blinds come with the Forester MBS for the front cab windows?
Thanks!
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 08-22-2015, 03:58 PM   #8
Is that new? I thought the refrigerator ran off 12v for the control circuits but needed 110v or propane for the cooling cycle.
ATVer is offline   Reply With Quote
Old 08-22-2015, 04:03 PM   #9
MarsMan's Avatar
Not sure how new. My Dometic can auto select propane, 12V or 110. Seems 110 is priority if avail, followed by 12v, and then propane. If the 12V voltage drops then it switches to propane. I have a 200W solar panel, seems like the 12V works well
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 08-22-2015, 04:07 PM   #10
I'll have to check on that about the fridge. Are you looking for the brand of curtains?
