Old 05-19-2016, 03:17 PM   #11
DaGrinch's Avatar
Glad I saw this. I, too, probably would have freaked out if I saw water pooling under my new 3010DS. But the reasoning is sound - long exhaust system, can't get the muffler hot enough to evaporate the water.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 05-19-2016, 03:56 PM   #12
mike.t's Avatar
Springerdad I was implying vehicles with Cats when I said newer.
Originally Posted by rad_jr View Post
Water is one of the results of the chemical reaction that occurs when exhaust gasses pass through the catalytic converter, much of which gets caught in the muffler. Since the muffler is so far from the engine (especially in one of our units), it doesn't get hot enough to boil off the water that it catches...hence the weep holes.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-20-2016, 12:21 AM   #13
benagi's Avatar
Thx for all the replies. Never noticed this on our cars in the past. This is the first I have heard of weep holes. Nice to know this is normal. One other question. Do exhaust gases come out of those weep holes and if so, is it anything to worry about?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 05-20-2016, 09:31 AM   #14
Sc00ter's Avatar
As mentioned above with water being a byproduct of the combustion process... If it leaks out of the weep hole, some exhaust will too. The amount will be very small. I wouldn't lay under it and breathe the air there, but I wouldn't stress it. I would be more concerned where the output of the tailpipe is. I.e. Pointed into someone else's camper door or if still at home, pointed into the garage.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 05-20-2016, 09:49 AM   #15
mike.t's Avatar
"Do exhaust gases come out of those weep holes and if so, is it anything to worry about?"
Really?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-20-2016, 03:04 PM   #16
Mike - before the cat 'lights off' and starts it's job, there's going to be water vapor headed down the exhaust to the muffler, which will condense - until the cat gets hot enough, which happens pretty quick. Those cats will run at 1000 degrees or more. They have to for the catalyst to work. Once That cat lights off, you no longer have carbon monoxide, but carbon dioxide and water vapor. That hot gas is going to head down the exhaust and dry things out. Anyone with an infrared thermometer ever taken a reading of their exhast systems after a highway run? We watch egt's on our diesels,,,,,, I can see egt's of 12000 degrees on a pull with my camper regularly. All that heat goes,,,,, down the tail pipe.
EDIT - I should add that depending on engine, exhaust configuration, and muffler baffle placement, a muffler may or may not have a weep hole. Generally. The farther downstream it is, the more likely you wil. have one. Some engineer somewhere in the Big Tower decided all that.
Springerdad is offline   Reply With Quote
Old 05-20-2016, 11:48 PM   #17
vasnipe's Avatar
Weep hole
My 1997 Honda CRV had the weep hole in the muffler.
Dealer (stealer?) failed it on a state inspection and tried to tell me that I needed a whole new exhaust system. From stem to stern, like abut $700 or so. Ummm, no. I didn't fall off the turnip truck this morning.
Told them to slap a rejection sticker on it and took it to a private muffler shop who took one look and said it was fine. Took the car to my regular mechanical type and he said the same. No problem, the weep hole is there for a purpose.
Guess that dealer (really a stealer in this case?) thought he had a live one...
My 2006 Sunseeker E450 muffler weeps a bit until things are really warmed up.
10 years old and going strong.
Ask any questions you need to here.
Someone will come along with the information you need.
I have learned a lot here and have helped some a bit.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
leak
