Old 05-19-2016, 12:52 AM   #1
benagi's Avatar
Muffler on E450 leaking moisture.
Has anyone had this problem. You know when you first start a vehicle, moisture usually comes out of the exhaust pipe. That is normal. But when I have moisture dripping on the ground just below muffler, there is something wrong. Looks like it is coming out of the seams of the
muffler. Won't take long for this to rust out along with a major exhaust leak. Guess I need to take this problem to Ford and not CW. Our unit is less than a year old.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 05-19-2016, 04:22 AM   #2
nomad297's Avatar
Many/most mufflers have drain holes for condensation. This is probably "leaking" by design.
Bruce
Old 05-19-2016, 05:49 AM   #3
Bruce
X2 That's the norm so they do not rust out too fast. Even the stainless ones have a small drain hole.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is online now   Reply With Quote
Old 05-19-2016, 05:54 AM   #4
davel1971's Avatar
normal. Don't worry about it.
David & Lynn
Old 05-19-2016, 10:07 AM   #5
Sc00ter's Avatar
Yep every vehicle we have has a weep hole at the bottom of the muffler. Better to let the water out than to stay in the muffler.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 05-19-2016, 10:10 AM   #6
Pickin' & Campin'
It is not uncommon for moisture to leak from a muffler, pipe joint or any other area that is joined in some way. It is the nature of the beast.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-19-2016, 11:54 AM   #7
mike.t's Avatar
All newer vehicles drip.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-19-2016, 12:55 PM   #8
It's been that way for as long as the hills are old. As was said, it's a drain hole to let all that acidic water drain out so the muffler doesn't rot prematurely. Be glad it's doing it's job.
Springerdad is online now   Reply With Quote
Old 05-19-2016, 01:18 PM   #9
Our 2015 F-150 has weep holes to let any pooled moisture drip out instead of sitting in the muffler and rusting it out faster. After coming from much older vehicles that didn't have them it was a surprise when I first saw the little puddles but it made sense once I found out what they were for.
keith_h is offline   Reply With Quote
Old 05-19-2016, 03:10 PM   #10
Water is one of the results of the chemical reaction that occurs when exhaust gasses pass through the catalytic converter, much of which gets caught in the muffler. Since the muffler is so far from the engine (especially in one of our units), it doesn't get hot enough to boil off the water that it catches...hence the weep holes.
rad_jr is offline   Reply With Quote
leak
