Old 01-02-2019, 06:09 PM   #1
My Atwood ducted 15000 btu ac/heat pump is draining inside the coach
It stopped draining outside and down the roof. Right now I have a bucket on the floor under the ceiling unit. Any ideas?
V/R
rch
RHOUSER is offline   Reply With Quote
Old 01-02-2019, 06:25 PM   #2
I am adding some more info. 2018 2501TS. I am in Florida at an RV park so the unit is under load. It has been draining fine for the last 2 weeks. Today nothing is draining out and down the gutters on the roof. It is coming down from inside the a/c unit through the vents. Thanks. rch
Old 01-02-2019, 06:28 PM   #3
It could be the A/C drain pathways on the roof are blocked. You would need to get on the roof and remove the A/C cover to inspect the drainage passages. If the drains are blocked, you should see a puddle of water that is working its way into the RV.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 01-02-2019, 06:31 PM   #4
Usually Confused Member
emm-dee's Avatar
Pretty sure this is not the complete problem but call Dometic and ask about Service bulletin 3315930.010. It involves new diverters in the unit, etc. I had minor leaking and did the mod..problem solved. They sent the parts at no charge. Easy install.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 01-02-2019, 06:32 PM   #5
Remove the cover? I am in my first month. Is removing the cover fairly obvious or am I in for a bad time.
V/R. rch
Old 01-02-2019, 06:36 PM   #6
Flybob's Avatar
Removing cover is easy. You should see a few large head screws that hold the fiberglass cover on. While working on the roof try to distribute weight if possible.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-02-2019, 06:36 PM   #7
Check out You Tube videos on this subject. Removing the cover is not hard, usually some screws around the cover bottom need to be removed. Being careful on the roof is important. I am assuming that your roof can be safely walked upon.
The evaporator coil under the cover has a drip pan that may have clogged drain holes.
2015 Rockwood A128S
2010 Rockwood 2604
Old 01-03-2019, 07:46 AM   #8
Duckogram's Avatar
Been there, done that, posted the results.
First suggestion is that you remove the mesh filter and clean it. Following that,
and now that you are no longer raining inside, read this;
AirCommand Water Penetration
I am also at an RV park in FL. The humidity increased to rediculous over the last couple of days. Thats why you found the design problem. The fix is free but they still do not have the garnish to cover the old holes.
ILB ( | )
Old 01-03-2019, 08:09 AM   #9
nomad297's Avatar
This is usually the problem. Easy fix. Donít sweat it.
Bruce
nomad297 is online now   Reply With Quote
Old 01-03-2019, 08:09 AM   #10
RedLdr1's Avatar
Until you can have the "fix" linked above installed just remove the air filter from the A/C unit located inside your Forester. The filter acts as a funnel and routes the water down to its base causing the drip. Pull the air filter and the funnel is gone...and so is most of the dripping...
The "fix" does leave some interesting holes in the ceiling... If Dometic doesn't get off their butt and come up with a new garnish before spring I suspect they will be hearing from my DW...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
500, drain, pump
