Old 01-17-2019, 10:13 AM   #1
My Propane Furnace is coming on automatically
FR 2501 TS 2018 with Air Command 15000 ducted AC/Heat Pump. I have been using the heat pump only with gems between the 40’s and mid 60’s with great success. I noticed last night (38 degrees) that heat was coming out of the floor vents. This would be normal if the propane furnace was turned on. I have not turned on the propane furnace using the control pad. The furnace light is not on.
Any one else see this “feature”? My temp is right where I want it, so no complaints. I am just a little confused.
V/R. rch
RHOUSER is offline   Reply With Quote
Old 01-17-2019, 10:28 AM   #2
My rig has to Air Conditioners with heat pumps. When the temp gets too low, it will automatically turn on the furnace.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 01-17-2019, 02:00 PM   #3
Ok, I think I get it now. On ac current it will automatically support the heat pump. On dc current it will come on and operate without the heat pump (selecting the furnace button).
How long can I run the furnace on the house battery until it has to be charged? I know it would depend on temperature and heat settings. Is overnight (10 hours) realistic?
Thanks rch
Old 01-17-2019, 02:11 PM   #4
The furnace fan is a big 12 volt power hog. One night is possible with one deep cycle battery and the temp set lower.
Old 01-18-2019, 12:16 PM   #5
dcheatwood's Avatar
Heat pump can only produce heat if outside temps are above 45° or so. Below that temp the furnace comes on to provide heat. As I understand from owners manual.
2018 Forester 3011 DS
Old 01-19-2019, 11:19 AM   #6
Wolverine 1945's Avatar
I totally understand being confused when things work well in a R/V !!!
Not the Normal !!!
Wolverine 1945 is offline   Reply With Quote
Old 01-19-2019, 08:30 PM   #7
dcheatwood's Avatar
Not the Normal !!!
That's a good one. [emoji1]
forester, furnace, propane
