My Propane Furnace is coming on automatically
FR 2501 TS 2018 with Air Command 15000 ducted AC/Heat Pump. I have been using the heat pump only with gems between the 40’s and mid 60’s with great success. I noticed last night (38 degrees) that heat was coming out of the floor vents. This would be normal if the propane furnace was turned on. I have not turned on the propane furnace using the control pad. The furnace light is not on.
Any one else see this “feature”? My temp is right where I want it, so no complaints. I am just a little confused.
V/R. rch
