Old 01-03-2017, 07:22 PM   #1
Mystery Switch
There is a switch on the control panel of my 2012 3011DS that says Livingroom Light. Can anyone tell me what this controls? The living room lights are controled by a separate switch with dimmer located on the wall below the control panel
Mach428 is offline   Reply With Quote
Old 01-04-2017, 08:33 AM   #2
Are you the original owner? It sounds like someone wanted a dimmer and bypassed the original switch.
jrwalkerpa1 is offline   Reply With Quote
Old 01-04-2017, 11:59 AM   #3
Not the original owner but the switch & dimmer are the same as the other switches.
Old 01-05-2017, 11:19 AM   #4
Perhaps the original owner did the same as I did:
The switches in the "Convenience Center" were less than convenient, so I added a pair that were easy to access. I purchased the switches from the large online retailer that are identical to the existing switches.
Additionally, I added a switch for the light over the sink:
I should replace the (now unused) switches with blank-out covers.
Perhaps the factory installed optional switches upon request, but the original switches were left in the panel...
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 01-05-2017, 11:49 AM   #5
I assume the switch in the panel once controlled the lights.
Thanks for both replays. It does make sense
switch
