03-30-2019, 11:36 AM
Need Reflective Tape on Bumper
Since our 3011ds (2018) has brown full paint, it cannot be seen easily when parked. We tried installing reflective tape on the (rough surface) rear bumper. Next morning, the tape had fallen off. How have you gotten reflective tape to stick on bumper? We don’t want to put tape on camper shell.
Thanks,
Dave Allen
03-30-2019, 12:04 PM
Denver To Yuma In 90 Days
I've had no problems with the reflective tape on my rear bumper...been on there almost four years now!
Got it at Walmart in the Auto department near the trailer hitch stuff.
But, why not stick it on the camper wall...no different than a bumper sticker.
I've also installed the tape on the front and back of both big slide-outs (front and back).
03-30-2019, 09:28 PM
My bumper is not a rough surface. Did you clean with alcohol first? Also best to not apply it when it's cold as it really tends to not stick then.
I put mine on the camper.
03-30-2019, 09:34 PM
Clean the surface well, and after applying the reflective tape is a hair dryer to heat the tape and set the glue.
2017 Keystone Cougar 28RDB
03-30-2019, 09:41 PM
Apply 3M DOT red/white tape to the body just above the bumper line if you want viability. It will stick there. Mine's been on for 10 years. While you're at it put the inverted L tape at the upper corners.
03-30-2019, 09:43 PM
I am a big believer on putting it high enough to see (ie the wall).
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
03-30-2019, 10:17 PM
Problem is that if you put it too high it won't reflect much back...if at all.
03-31-2019, 01:14 AM
Just as confused as you
Guess you have never followed a semi-trailer with reflective tape on the upper corners of the rear doors or noticed how high signs are above the road.
Richard & Jill
03-31-2019, 01:04 PM
Too old to be too smart
Disagree with this.
Have you ever used this tape? Quite useful stuff.
I even put it on our camp chairs so that they stand out when mixed with others.
3M "Scotch" brand isn't the only available, but it has great adhesive, and does what they say it will do.
Alcohol surface prep works wonders to make 'em stick.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
03-31-2019, 01:31 PM
Actually, Harbor Freight has good tape at a low price. Has held up well for over 4 years for me.
03-31-2019, 02:43 PM
(o˘◡˘o)
Conspicuity Tape
Here is a good explanation of DOT-C2 tape requirements in case you are interrested:
https://reflectivetape.info/what-is-...pecifications/
For best reflectivity in low light or off angles, consider a glass bead or microprismatic tape.
03-31-2019, 03:47 PM
I placed a 12” piece on our rear wall, either side about 3 feet from the bottom. Same on front and back if our slide. Always visible and sticks great.
03-31-2019, 05:30 PM
Or the new School Buses with the yellow reflective tape all over the place, even around the side windows. Yep, when the lights hit those, there’s no way you won’t see them
03-31-2019, 10:47 PM
Tape
Get the DOT reflective tape from an auto parts store or tractor supply. Clean surface w/ alcohol, it will not come off. Come in two 3' pieces, $15. I have on my trailer and bike rack.
