Old 03-30-2019, 11:36 AM   #1
Need Reflective Tape on Bumper
Since our 3011ds (2018) has brown full paint, it cannot be seen easily when parked. We tried installing reflective tape on the (rough surface) rear bumper. Next morning, the tape had fallen off. How have you gotten reflective tape to stick on bumper? We donít want to put tape on camper shell.
Thanks,
Dave Allen
Psadave46 is offline   Reply With Quote
Old 03-30-2019, 12:04 PM   #2
Denver To Yuma In 90 Days
I've had no problems with the reflective tape on my rear bumper...been on there almost four years now!
Got it at Walmart in the Auto department near the trailer hitch stuff.
But, why not stick it on the camper wall...no different than a bumper sticker.
I've also installed the tape on the front and back of both big slide-outs (front and back).
JohnD10 is offline   Reply With Quote
Old 03-30-2019, 09:28 PM   #3
dbledan's Avatar
My bumper is not a rough surface. Did you clean with alcohol first? Also best to not apply it when it's cold as it really tends to not stick then.
I put mine on the camper.
dbledan is offline   Reply With Quote
Old 03-30-2019, 09:34 PM   #4
Clean the surface well, and after applying the reflective tape is a hair dryer to heat the tape and set the glue.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 03-30-2019, 09:41 PM   #5
Chuck_S's Avatar
Apply 3M DOT red/white tape to the body just above the bumper line if you want viability. It will stick there. Mine's been on for 10 years. While you're at it put the inverted L tape at the upper corners.
Chuck_S is offline   Reply With Quote
Old 03-30-2019, 09:43 PM   #6
Herk7769's Avatar
I am a big believer on putting it high enough to see (ie the wall).
HAM CALLSIGN - KC3FFW
Old 03-30-2019, 10:17 PM   #7
Problem is that if you put it too high it won't reflect much back...if at all.
Old 03-31-2019, 01:14 AM   #8
Just as confused as you
Scrapper's Avatar
Guess you have never followed a semi-trailer with reflective tape on the upper corners of the rear doors or noticed how high signs are above the road.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 03-31-2019, 01:04 PM   #9
Too old to be too smart
SpringerPop's Avatar
Disagree with this.
Have you ever used this tape? Quite useful stuff.
I even put it on our camp chairs so that they stand out when mixed with others.
3M "Scotch" brand isn't the only available, but it has great adhesive, and does what they say it will do.
Alcohol surface prep works wonders to make 'em stick.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 03-31-2019, 01:31 PM   #10
Bluepill's Avatar
Actually, Harbor Freight has good tape at a low price. Has held up well for over 4 years for me.
