Old 02-06-2016, 06:05 PM   #1
Need water help
Trying to dewinterize. Filled the fresh water tank and water goes right out of the hose to the ground. There is no cap on that hose. Is there a shut off valve somewhere. Why is it draining right out? We left the hose connected to the city water input and can run water that way. What's w the fresh water tank? Thanks
critt61626 is offline   Reply With Quote
Old 02-06-2016, 06:13 PM   #2
Left Coast
drain open...might have to remove or open a panel to get to it
Old 02-06-2016, 06:23 PM   #3
Hsunseeker 2016 2650. Any idea where it may be?
Old 02-06-2016, 06:28 PM   #4
fonzie's Avatar
https://www.google.ca/search?q=sunse...-bLsire83KpsgP
These may help...
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-06-2016, 07:13 PM   #5
Old Camping Squid
Eagle-751's Avatar
I know we have different campers but my shut off was tucked up high and I had a hard time getting my hand up along the side of the tank to open / close it. I added a new valve to the drain below the tank. Maybe your valve it above just out of sight...
Larry Collins { PM }
2006 F150 Supercab 5.4 Flex Fuel
2017 H-D FLHTK Ultra Limited
2006 BRP Outlander XT
2009 Forest River Salem 30QBSS
U.S. Navy Veteran
Eagle-751 is offline   Reply With Quote
Old 02-10-2016, 11:07 AM   #6
What model? In our 2250, the water drain valve is accessed via the drivers rear storage compartment. Open the compartment, look high to the left, near the ceiling for a round access port. Open the port, the valve is just inside.
Here's a pic of the valve from inside the space containing the tank and plumbing - you can see the drain valve and the inside of the access port:
Hope that helps!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 02-11-2016, 12:56 AM   #7
MNtraveler's Avatar
Look right where the water comes out the underside and go straight up that line until you find the valve.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 02-14-2016, 11:34 AM   #8
MNtraveler's Avatar
Any luck?
Land of 10,000 Lakes
2016 Forester MBS 2401R
Old 02-14-2016, 04:14 PM   #9
X2
Sent from my LGMS345 using Tapatalk
gtp618 is offline   Reply With Quote
water
