Old 05-23-2016, 04:30 PM   #1
New 3051 with front wheels needing alignment
Any new owners with really bad front end alignment problems? The bottom of the front tires are toed in and the tops are toed out. I have never seen anything like this before.
13STL is offline   Reply With Quote
Old 05-23-2016, 09:36 PM   #2
sgtlm17's Avatar
That's how my front tires are on my Forester GTS 2801QSF. It drives great. I know the specs are different from FR than what Ford uses. My unit drives perfectly straight. Only 1000 miles on it so far. Some say wait till about 2500 miles before changing anything.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 05-24-2016, 12:54 PM   #3
I only have about 1100 miles on my 3011 and will be waiting till about 2000-2500 myself to get an alignment which FR said they would cover. In addition to the various threads here that recommend waiting, a local truck shop that specializes in alignments also said to wait until then just to give the suspension components some time to break in. As for the toe in/out condition mentioned above. I can see how that would happen since the cabs come aligned from Ford with no weight on the back and depending on the center of gravity in the RV and how much it is loaded and the weight distribution, you might see that condition? yes?
newRVer is offline   Reply With Quote
Old 05-24-2016, 08:07 PM   #4
Well in our case, the toe in/out is in an empty (not loaded) 3051.
Old 05-24-2016, 09:48 PM   #5
We picked up a 2014 3171 a few months ago with 3600 miles. Had it aligned, toe was way out. It made a huge difference in steering manners, I don't feel like I'm chasing it all over the road anymore.
Keep in mind these chassis roll off the line from Ford with one suspension and alignment setup. FR extends the frame and turns them into a 14,000lb truck, but doesn't change the alignment or suspension components. So you and the average 15 passenger van have the same setup...
vajeep is offline   Reply With Quote
Old 05-25-2016, 06:35 PM   #6
JimOneil43's Avatar
We just picked up our new 3051S in Ohio and are on our way back to Oregon, so we'll have about 2400 miles on it when we get home. We plan to take it in for alignment as soon as we can and also install a steering stabilizer. The handling is all over the road, especially on bumpy highways and in crosswinds. After 2400 miles, I think my arm strength has increased a lot, just keeping it in the road.
Love the 3051S anyway.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 05-28-2016, 10:50 AM   #7
Citrus County, Fl.
GL1800Rider's Avatar
I agree your arms get a workout on a trip. Still need to find a competent shop to get my alignment done. Ian am just under 4000 miles so it's time. Only problem is FR will only pay for it during the first 3 months and I only had about 1500 at that time.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 06-08-2016, 06:21 PM   #8
2015 Coachmen Mirada 32 UD, just returned from Josam Frame Alignment in Orlando. They performed a front axle alignment along with adjusting caster and installing a shim. A rear Super Steer Rear Tracbar and the drive home was amazing. What a difference in the steering and sway, almost nile and know the big rigs do not blow me around like a kit. Steering is sharper and responsive and it's a joy to drive. My ride home was 2.5 hours so I had a good chance to compare from the ride down to the return, two totally different experiences. Brad at Josam did not over sell and delivered what he promise, best money spent on the RV yet. White knuckle experience no more.
Rico8251 is offline   Reply With Quote
Old 06-08-2016, 09:54 PM   #9
I did my alignment today. Currently have 3,780 miles. Its a 2015 FR 2861DS. Made a huge difference in handling. No longer pulling to the right.
How to we get reimbursed by FR for the alignment. Biught my RV brand new 3 months ago from CW.
ADOR is offline   Reply With Quote
Old 05-17-2017, 04:20 AM   #10
Is there a spec from FR for the alignment? And how do I get this info? Or do i just have it aliigned while it is loaded? Do I need to buy offset bushings before taking in for alignment or is that something alignment shops will have?
2017 3011DS
Azzy1016 is offline   Reply With Quote
305, alignment, wheel
