03-17-2015, 03:46 PM
New RV won't start
Picked up RV last week. Stopped on the way home and it started up fine. Battery is full, but engine won't turn over. Tried both keys. Don't want to run battery down. Anyone have a problem like this? its a Chevrolet chassis. 2501tsc
03-17-2015, 06:22 PM
If you have the slides out it won't start, just a suggestion
Pennie and Chuck, Mandi and Polly (the little dogs)
Hosted BamaGanza 2017 & 2018
2014 Georgetown XL378, 2014 GMC Acadia Denali Toad
The Home of the FREE because of the BRAVE
03-17-2015, 06:25 PM
Only because I've done it before, make sure it is in either Park or Neutral.
03-17-2015, 07:54 PM
Does it crank when you turn the key or nothing?
03-17-2015, 08:12 PM
Cranks but won't turn over. Like when you have a weak battery, but battery is good
03-17-2015, 09:55 PM
Just a thought. If the awning is out, it will not start. Press the awning switch and make sure it is seated in its stowed position.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
03-17-2015, 11:26 PM
"Cranks" and "turning over" mean the same thing. Are you saying that the motor does "crank", but will not start and run?
03-18-2015, 05:16 AM
"Exactly"^^^^, Cranking over and Turning over are one in the same.
Does the engine crank, turn , spin, in a normal fashion but not start up and run?
The statement was made it sounds like a "Weak Battery" when cranking but the battery is good, How do you know the battery is good? What are you basing that statement on?
If the battery is in fact good, and if the engine is "Cranking Over", but not starting up and running, do you see an Anti-theft lamp flashing in the instrument cluster?
Have you tried to jump start the vehicle?
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
03-18-2015, 05:25 AM
Probably have it going by now. But will the generator start.
Russell
03-18-2015, 09:41 AM
Yes. Cranks not weakly but doesn't start up . Have have battery charger. Anti theft not on. This RV only has 600 mi on it.
03-18-2015, 10:00 AM
Sounds like it is time for a call to the Dealer, either RV or GM, one or the other. Seems like you have covered what should be on you as far as possible drained or weak battery. I would let them deal with it now since it is a brand new unit.
03-18-2015, 10:29 AM
Well then, time to buy a new one! Kidding...kidding. We assume this is a gas engine on a Chev chassis and not a diesel? Just sayin...
03-18-2015, 11:06 AM
They are coming to toe it to the shop. We give up. Not a good way to start
03-18-2015, 11:08 AM
Don't be discouraged. It will be fixed for free and then you will be good to go. New mechanical issues happen.
03-18-2015, 11:33 AM
These chassis must have a fuel shutoff switch, just like a truck. In case of an accident. Possibly it has been tripped.
B and B
03-18-2015, 11:44 AM
how old is the gas it might have sat in the tank over winter and could have water in gas if stabilizer was not used
03-18-2015, 07:37 PM
Please post the fix to your problem. Helps all learn.
03-20-2015, 11:37 PM
I think they said what the issue is. It's on a Chevy chassis
03-21-2015, 07:51 AM
A lot less issues on the Chevy chassis than the Ford Chassis!!
03-21-2015, 10:41 AM
I think you NAILED it BWB! Even "new" can succumb to ignored tricks-of-the-trade, right? Hopefully it was as simple as this fix.
