Old 04-04-2019, 04:12 PM   #1
No OTA reception on bedroom TV
It used to work fine, now when scanning it says check antenna cable and rescan. Checked and everything is hooked up. Booster is turned on. Living room area TV is fine. Donít know where else to check connections. Coxial hookup seems to disappear into the ceiling so where do I look now?
Gaga1951 is offline   Reply With Quote
Old 04-04-2019, 04:33 PM   #2
Denver To Yuma In 90 Days
Guess that is a good place to start...
JohnD10 is offline   Reply With Quote
Old 04-04-2019, 04:36 PM   #3
A32Deuce's Avatar
By any chance an out door or compartment tv location? Could be a bad/disconnected splitter.
A32Deuce is offline   Reply With Quote
Old 04-04-2019, 04:37 PM   #4
A32Deuce's Avatar
I have found broken center wire at the connection. If so, needs to be re-spliced.
Old 04-05-2019, 11:07 AM   #5
I have the exact same problem. I'm guessing it's a bad/disconnected splitter hidden in the ceiling somewhere. I just haven't gotten around to actually finding it.
I know they make endoscope cameras that can hook up to a cell phone that aren't too expensive. I'm thinking I might need to get one of those and trace the coax in the ceiling.
Iwritecode is offline   Reply With Quote
Old 04-05-2019, 01:25 PM   #6
D W
D W's Avatar
Also, check the coax connector on the back side of the bedroom wall plate to make sure the crimp is intact and the connection is tight.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 04-05-2019, 03:25 PM   #7
OldJarHead's Avatar
I went through a similar scenario. To troubleshoot, I removed all 4 coaxial wall plates, i.e., living room (2), bedroom, and outside. I then removed and closely inspected each coax cable to ensure the compression fittings were installed correctly and that the center conductor (wire) was intact and long enough. I was surprised at how loose ALL the connectors were. I re-tightened them all and snugged them using a pair of pliers. I did find what appeared to be a piece of the ground shield inside of the bedroom cable connector that couldíve been attenuating my reception in the bedroom.
I found a 3-way splitter behind the wall in the living room connected to SET 2 of the amplifier wall plate output, while the splitter outputs went to the living room television directly, the bedroom television wall plate and the outside television port.
In addition, I have a home run for a satellite connection outside to a separate coax connector in the living room AND a home run from the living room to the bedroom for connecting the the satellite receiver output to send it back to the bedroom.
I took the time to document my coax wiring on a drawing for my specific camper.
Hope this helps to get the troubleshooting wheels turning.
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
OldJarHead is offline   Reply With Quote
Old 04-05-2019, 03:48 PM   #8
Just as confused as you
Scrapper's Avatar
It used to work fine, now when scanning it says check antenna cable and rescan. Checked and everything is hooked up. Booster is turned on. Living room area TV is fine. Don’t know where else to check connections. Coxial hookup seems to disappear into the ceiling so where do I look now?
I had a booster go bad in my TT after 2 years. The booster would work fine once I took it out of the wall, when I put it back in I would loose the signal.
See this thread for what I did to fix the problem. do i need a coax cable for campground cable tv
Richard & Jill
Camping since 1989, seasonal since 2000
Old 04-06-2019, 02:20 PM   #9
Determine which coax on the back of your amplifier is for the bedroom TV. Connect a video source directly to that coax such as a DVD. If the TV works, there is nothing wrong with the coax (and any connections / splitters) going to the TV. If the LR TV works From the antenna, the problem is likely in the selector box / amplifier.
Process of elimination works in most instances
Mach428 is offline   Reply With Quote
bed, reception, roo
