Old 03-09-2019, 08:24 PM   #1
No power
I left my new Forrester parked without electricity for a couple of days. Then I ran the generator for 8 hours, no electrical power (lights, etc.). then I plugged it in for 5 hours, no power. What do I have to do now, get a jump? get a new battery? Help. I am new to having a Motorhome. I will be storing it for a few weeks at a time. Do I need to bring it home every week and plug it in?
Thanks for your help.
cmartz is offline   Reply With Quote
Old 03-09-2019, 08:31 PM   #2
ejohnson1144's Avatar
Check your breakers . a couple days should not have killed the Battery and if you plug in you should have 120volts.
ejohnson1144 is offline   Reply With Quote
Old 03-09-2019, 08:33 PM   #3
Did you turn on battery disconnect?
Old 03-09-2019, 08:34 PM   #4
Flybob's Avatar
Need a little more data. Does the light on the microwave work? Does the TV work? If the battery was low when you powered the rig, it could have blown the reverse polarity fuses trying to charge a very depleted battery. Check the two High current 30-40A fuses in the distribution panle or back of the converter.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-10-2019, 08:04 PM   #5
I just saw these replies. Thanks. I will try these things in the am
Old 03-13-2019, 12:05 PM   #6
Kirk S's Avatar
You should have 12 volt power for lights, vent fan, furnace etc. unless battery is dead or disconnected.
You should have 120 volts for air conditioner, microwave, converter which keeps batteries charged when plugged in or running generator which has it's own breaker.
As mentioned, check breakers, battery disconnect switch and battery (water level in each cell, cable connections).
Let us know what you did to solve please.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
power
