Old 07-27-2016, 04:28 PM   #11
Originally Posted by Copikat View Post
My generator is in the front of the coach under the drivers seat of the class c motorhome. Can not find a black box only junction boxes.
Sorry that I can't be of more assistance. Knowing how cheap they go when they build these things, the wiring from the generator and the shore power connection to the transfer switch won't be any longer than absolutely necessary.
It will also be located in a water resistant enclosure and if you have a 120 volt 30 amp service like the brochure says, the transfer switch will have orange romex running from the shore power outlet and the power distribution panel to the transfer switch. I would wager that the flexible liquid tight conduit running from the generator isn't any longer than absolutely necessary because if its and its fittings cost.
What you need to do is open the access panel underneath the power distribution panel and see if there is an orange romex. if so see if you can determine which direction it goes and continue to follow it, eventually it will lead you to the transfer switch. If isn't orange figure out what color it is and follow that romex.
If you prefer you can start at the shore power connection and work your way towards the transfer switch from there.
FYI, I spent almost three hours this morning attempting to trace what I thought was the "C" channel speaker wiring. At the back of the Jensen JMW6A the "C" channel left speaker output was connected to a green/white lamp style cord. Others had told me that the "C" channel was connected to a sub woofer that was located under the clothes closet so I started looking there. Well I never did find the subwoofer nor the the green/white channel "C" wire.
What I did find was a green/white wire under the close closet, but it ran from the driver side outside light to the 12 volt power panel via the bed box out, the transfer switch compartment, a floor joist cavity, under the bathroom sink, up the wall alongside the fridge, and finally connected to the power panel wiring.
The orange #10 romex from the shore power outlet to the transfer switch ran into the cabin then exited the bottom of it, ran though liquid tight flexible conduit along the frame and then up into the transfer switch compartment where it exited the conduit and then the romex entered the transfer switch enclosure.
The orange #10 romex from the power distribution center ran over the fridge,down the wall alongside the fridge, under the bathroom sink where it entered the floor joist cavity, it exited the floor joist cavity in the transfer switch compartment and finally entered the transfer switch enclosure.
I still have no idea where that damn speaker wire goes and will not waste my time looking for it until I figure out how to remove the ceiling speaker covers without damaging them nor the soft ceiling.
I guess if you want to own a motorhome and don't have money to burn, you need to get your hands dirty and figure out where things are. The way these things are built. I am quite sure that mechanic at the RV service center has to do exactly what I did the first time they work on a new model.
ShermanD is offline   Reply With Quote
Old 07-27-2016, 05:06 PM   #12
HopHed's Avatar
I have the 2861 and the transfer switch is under the bed. Lift up the plywood panel the mattress is on and look on one of the sides to see if it might be there.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 07-27-2016, 05:07 PM   #13
Copikat's Avatar
Thank you so much for the help you have given we had a Alfa Seeya Gold before this one and yes they hide every thing, this one that we have now has so much grey foam sprayed every where that you can't tell what your looking at. We have a Mobil RV Tech coming tomorrow we have looked every where for this darn thing, maybe he can find it.
Thanks again for all your help
Copikat is offline   Reply With Quote
Old 07-27-2016, 05:12 PM   #14
Copikat's Avatar
We have looked under the ply wood under the bed not there eighter just out side shower hoses and grey junction boxes (2) .
Old 07-27-2016, 08:44 PM   #15
KJcachers's Avatar
The 3051 generator is under the dinette. Check under the benches of the dinette. Also, in my 3051 there is an electrical junction box in one of the side compartments near the generator. It's way in the back so you might not have noticed it. Also, I have no idea if this has the transfer switch in it or if it's just a simple junction box.
Jason and Karen
2015 Forester 3051S
http://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 07-27-2016, 08:53 PM   #16
Copikat's Avatar
Thanks we will check under the bench seats.
Old 07-28-2016, 08:00 AM   #17
Copikat's Avatar
Looked under the bench seats not there!
Old 07-28-2016, 03:57 PM   #18
Copikat's Avatar
Well, we found it finally. Surprised to find it in a water compartment, where the water filter is. But that wasn't what was wrong the 30 amp plug In the wall of the motor home was never tighten the screws were very loose causing the electric to arc and finally Burt the ground it could have caught fire we we're lucky. My advice to all of you check yours.
Old 07-28-2016, 04:01 PM   #19
Mr. Dan's Avatar
Thank you so much for posting the solution to your problem! This technical detail may help others with similar situations plus you give honor to the time others spent trying to help.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 00; booked = 14
electric, power
