Old 04-02-2015, 12:59 PM   #1
No shore power
I have been getting our new 2651 ready for its true maiden voyage with water. Last fall we took it out for a long trip with no water. I have had the shore power plugged in for a couple of days. When I first plugged it in I heard the MW kick on so I knew I had power to the unit. Today I ran my generator, while it was plugged in for about 30 minutes.
Now I have no 110 in the unit. I have power to the plug going into the unit but nothing inside. I unplugged the shore power and ran the generator and still have no 110 power in the motorhome. I have checked the fuses that I can see and everything looks good. Does anyone have any ideas? I do not have much in the way of "electrical skills" but I can use a multi-meter. Ant help would be appreciated.
Gilm2113 is offline   Reply With Quote
Old 04-02-2015, 01:14 PM   #2
fonzie's Avatar
I would check main breakers in AC panel and also on generator to make sure none are tripped. Also possibly you have an auto-transfer switch that is acting up. Look for one of these and take cover off (shore power disconnected and generator not running) and see if the relays are stuck open.....
Name:	Georgetown breaker panel.jpg
ID:	72843   Click image for larger version
Name:	transfer switch automatic.jpg
Fonzie
Old 04-02-2015, 01:17 PM   #3
Thanks Fonzie, I checked the main breakers but not the ones on the generator. I will look for the auto transfer switch. We just cancelled our reservations for the weekend. Disappointed to say the least!
Old 04-02-2015, 01:34 PM   #4
I found the auto transfer switch but mine looks totally different than yours. I can't see the relays at all. Looks like a trip to the dealer.
Old 04-02-2015, 01:39 PM   #5
fonzie's Avatar
Yes auto-transfer switches can be different from one to another. Dealer technician should be able to check operation of transfer switch.....hope you still have a happy easter holiday...
Fonzie
Old 04-02-2015, 01:42 PM   #6
I appreciate your help, we will see what happens. I'm just want it done before our first big trip in May. You have a great weekend too!
Old 04-02-2015, 01:51 PM   #7
fonzie's Avatar
Here a you tube video that explains operation of a typical auto-transfer switch, just for info....
Fonzie
Old 04-02-2015, 03:52 PM   #8
Perfect, I will familiarize my self with the operation. I have a service appointment for this Saturday morning we will see what they say.
power
