Old 07-10-2015, 11:01 PM   #1
Creativepart's Avatar
Noisy table?
The dinette squeaks the most when we're driving down the road. Anyone got a fix for this?
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 07-10-2015, 11:52 PM   #2
Garrette's Avatar
yep, get underneath and tighten all the screws and if you have found any screws on the floor, screw them back in. tighten frame to wall screws and table to frame screws. oh, lower the table to get to the last 3 screws.
Garrette is offline   Reply With Quote
Old 07-12-2015, 09:08 AM   #3
I put felt in my last one that was squeaky. Lower the table and put it either on the bottom of the wood or on the top of the table. That seemed to help mine. You can also get an adjustable shower rod and put it at the end of the table, from the floor to bottom of table. That will limit the movement.
Brian217 is offline   Reply With Quote
Old 07-14-2015, 11:25 PM   #4
When I got under it to tighten the screws I found it wasn't all the way up, and locked in place. All better now. The screws however did not need any tightening.
Turns out the lock lever will look locked when the table is about 95% "up."
