Old 04-20-2019, 02:57 PM   #1
Onan Generator Circuit Breaker
In the aftermath of Hurricane Michael I let one of our employees live in our 2016 25' Forester for 6 months. When I got the motor home back I started up the (LP) generator just to run it and when I went to put a load on it I noticed none of the electric was working in the coach. I went to reset the breaker on the generator and it wouldn't reset and felt a bit "sloppy". It has kicked off in the past so I assume the breaker may be bad. Is this breaker hard to replace? Am I overlooking anything. Thanks for any suggestions. FYI we use or generator very little.
jenunn01 is offline   Reply With Quote
Old 04-20-2019, 03:45 PM   #2
Lacey's Spring, AL
formerFR's Avatar
I wouldn't think such a fairly new rig would have an issue with a breaker, but I guess it's possible - the breaker is still a typical breaker you would find at most hardware stores, though 'how' to replace it is the question...I suppose you have to remove the panel/cover of the generator to get to it - then it's simply unplugging it, removing the output wire, and replace it with the new unit, reattaching the output wire, and plugging back in.
One thing to check, first, though, is whether the current breaker's output wire is attached firmly...it could be that it's simply loose, not making a good connection.
formerFR is offline   Reply With Quote
Old 04-20-2019, 04:11 PM   #3
cavie's Avatar
Did you turn it off then back on? That's what you have to do with any breaker. Push it hard into off.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-20-2019, 05:23 PM   #4
Yes I did try to reset it several times. Like I said it felt unusually "loose". I'll check all connections before I try to replace it...thanks.
Old 04-21-2019, 03:07 PM   #5
the breaker is on the generator did you reset that one?
cfo111 is offline   Reply With Quote
Old 04-23-2019, 12:10 PM   #6
Our breaker on the gen popped once out in Glammis, when I was on a ride and my wife was back at the RV. not sure what happened just reset it and nothing since.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
breaker, generator, onan
