Old 03-01-2016, 07:36 AM   #11
Originally Posted by sgtlm17 View Post
Bigfoot levelers need to be calibrated it's very easy. Second page of Bigfoot instruction pamphlet.
Jensen radio has another setting for all volume. Turn nav to 6 and it will boost volume. Keep radio around a 2 or 3.
STL,
I did find the nav volume on the general setup and turned that up to 6. I completely forgot about that setting and am betting that should take care of it. As for the calibration, all the Bigfoot doc that I have makes no mention of it so I will probably be calling them today.
newRVer is offline   Reply With Quote
Old 03-01-2016, 12:08 PM   #12
Sealing Lights
After years of struggling with boat trailer lights, I figured out that a 1/2" large hole in the lens bottom lets the moisture out, without letting water in. Good LED lights are sealed, but I've had problems with some of the LEDs going out on my truck camper LED brakelight. I suspect a moisture issue, since the bulbs don't typically fail.
mnoland30 is offline   Reply With Quote
Old 03-01-2016, 12:34 PM   #13
sgtlm17's Avatar
Just remember don't level from a counter top. Level your rig using refrigerator.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 03-02-2016, 10:13 AM   #14
Total Loss's Avatar
Originally Posted by newRVer View Post
Sounds like you may have different lights than what we have on our unit. Attached picture to make sure. We have a single cover over on all thee tail light fixtures. It may be possible that leaks through the screw holes could be an issue (Air or water), especially if each of the lights does not have an inside gasket. The only way to tell might be to take off the covers.
Same lamps.
Mine only had 2 screws in the clear lense and would leak.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
