Old 10-13-2018, 10:54 AM   #1
Retired and Loving Life!
Alan F's Avatar
Send a message via MSN to Alan F
Out side TV Replacement
I have a 2017 Forester 3171DS, and last night the outside TV fried. I had it on when I started up the generator and the screen went blank. Now I have half screen and the other half just lines. How do I replace this TV? I can not see behind it and cannot feel a bracket behind. Anyone know how to get it out?
TIA
Alan F is offline   Reply With Quote
Old 10-13-2018, 12:10 PM   #2
Usually Confused Member
emm-dee's Avatar
Hold both sides of the tv about 2/3 down. With a slight rocking motion put a lot of upward pressure and it will pop out of the mount.
Generator shouldn’t have been a factor since the TV should be 12 volt. For replacement you’ll be able to use anything that fits as long as it’s 12 volt. Just remove the mount bracket from the back of the old TV...the mounting holes are universally set.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 10-13-2018, 02:57 PM   #3
Alan F's Avatar
Thank you. I will try it when I get home. Boondocking now at s football game. The TV was working fine until I started up the generator - and then it went black.
Old 10-13-2018, 03:50 PM   #4
emm-dee's Avatar
The mount is a simple two piece design used since the outdoor TVs are usually mounted firm to the wall with no adjustment. They’re held in place by weight and pressure so no removal of bolts or screws when unmounting. Here’s a pix of a widely used mount for RVs.
Old 10-13-2018, 03:59 PM   #5
Alan F's Avatar
Thank you for the info.
Old 10-14-2018, 07:48 PM   #6
oldkeywest91's Avatar
That TV should be an A.C. not D.C.,120 volt AC not 12volt D.C..sealed compartment so any same size TV can be used
oldkeywest91 is offline   Reply With Quote
Old 10-14-2018, 08:16 PM   #7
Alan F's Avatar
Really? Even though it was running off the battery before the generator was started up? No other 120 volt appliances will work without the generator running.
Old 10-14-2018, 08:20 PM   #8
emm-dee's Avatar
Sometimes yes, sometimes no. Every Forester Iíve seen the past few years had 12 volt DC televisions. Mine (3051) has three, all 12v.
Old 10-14-2018, 08:29 PM   #9
Sorry,talked to friend who has one said he added convertor to his so he could have AC TV outside
Old 10-18-2018, 01:07 AM   #10
Sagecoachdriver's Avatar
Is the TV a Jensen 32"? If so, try calling them as they have fairly good tech support. Perhaps it just needs a reset of sorts and maybe it's still under warranty!
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 2 trips 7 nights
Sagecoachdriver is offline   Reply With Quote
replacement
