Old 07-05-2019, 01:20 PM   #1
Outside TV - 3050S
Outside TV (Insignia 32') won't power on. I got underneath the couch on the inside to try to track the power source, but I can't locate it. Anyone have theirs go out?
ksdindy is offline   Reply With Quote
Old 07-05-2019, 08:40 PM   #2
Is it 12 volt dc or 110 volt ac?
BIRDS AREN’T REAL
Old 07-06-2019, 08:13 AM   #3
12v
Old 07-06-2019, 10:10 AM   #4
Find the main box containing all the circuit breakers and fuses. On the Forester version of your unit it is on the small inward facing panel below the refrigerator. There should be 10 15 amp fuses there and on is labeled Outside TV.
The Forester models use a Progressive Industries power control center so the Sunseeker may be different (WFCO) but similar.
BIRDS AREN’T REAL
Old 07-06-2019, 01:11 PM   #5
The outside TV on my Forester 3011DS did the same thing. I just pushed on all the connections behind the TV and it came on. Probably vibrations jarred the connections loose a little.
Gideon is offline   Reply With Quote
Old 07-06-2019, 02:38 PM   #6
They definitely will do that. Also, OP should use a meter or light tester to check for power at the connection. If no power then fuse check time.
BIRDS AREN’T REAL
305, 3050s, sunseeker
