Old 08-12-2018, 10:18 PM   #1
Usually Confused Member
emm-dee's Avatar
Outside TV access
My 3051 has the standard Furion television installed on the side of the rig immediately behind the right cab door. It looks like the factory set up a tv and then built the MH around it. No way to access anything behind the set nor can I find anyway to remove it.
I rarely watch over the air TV and since there is no access to the HDMI ports I cannot connect my Apple TV box, or anything else. Has anyone had any success solving this problem?
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 08-13-2018, 06:02 AM   #2
No-Fish's Avatar
I don't remember the setup you have, I did look at a 3051, Ive got a 2016 3011, w/ a outside TV. Mine snaps in on the rt side of the TV, Its a little tight. To release the TV pull it on the rt side of the TV, about mid way down. I don;t use it , mine came w/ the trash can behind the TV, I removed the trash can and use the area for storage.
You may have to use a quick jerk to release the TV
hope this helps
No-Fish is offline   Reply With Quote
Old 08-13-2018, 07:18 AM   #3
emm-dee's Avatar
That works except the TV is pulled up rather than right. Thank you for the quick and accurate response. It’s amazing to see the amount of info on this forum.
Old 08-13-2018, 06:02 PM   #4
No-Fish's Avatar
Glad it worked
happy Travels
