Old 09-12-2014, 11:12 AM   #11
GM
bclemens's Avatar
Correct. The Jensen stuff inside works fine that way. I'll have to look at the outside TV set up next week at our wholesale show. I can play around with it then. I had asked about that a while back (if it was even possible) and they said it was not set up that way.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-12-2014, 11:15 AM   #12
Thank you . I appreciate your help.
dmnsen is offline   Reply With Quote
Old 09-12-2014, 11:51 AM   #13
My #3051 TV Audio Settings
When using the outside 32" HDTV I use the speakers from the radio for audio.
1. My radio mode input is set to AVIN R. Highest volume is 48 when dial is turned to maximum.
2. My TV Menu under AUDIO is set to TV Speaker OFF.
3. My TV Menu under SETUP your AUDIO OUTPUT should be Fixed
This works best for me, but if you play the outdoor radio it will blast at a volume setting of 48.
After my first summer in the RV I decided to install a speaker selector box and wiring. This allows me to control my dash radio and send it's audio signal to my outside speakers. Why? because now I can listen to Sirius XM radio outside.
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 09-12-2014, 12:19 PM   #14
Thanks trwmodela for the input. My problem is I've set it up exactly the way you describe but I get nothing from the radio speakers. I will have to go through all the set up again and see if I missed something. And I like your idea for XNM on the outside. Thanks again.
Old 09-12-2014, 01:06 PM   #15
Turn the volume knob on the outside radio all the way up to 48.
Tim
Old 09-12-2014, 01:10 PM   #16
Ok. I have done that and as long as tv speakers are on I get a "little" better sound than I do just from the tv. If tv speakers are off and volume up to 48 I can't even hear sound. Seems to me that for whatever reason that's the best it's gonna be. Will have to live with it I guess. Thanks again
David and Susan
Retired May 2017
South LOUISIANA
2014 Forest River 3051S Class C
2017 Jeep Wrangler Sport
Old 09-12-2014, 01:18 PM   #17
Make sure (TV Menu) under SETUP your AUDIO OUTPUT should be Fixed not Variable. (TV Menu) under Audio AVC to Off.
Tim
Old 09-12-2014, 01:30 PM   #18
Ahhh. I bet that's it ! I've been changing AVC to off but did not see where you could change audio output to fixed. Just looked in tv manual ( should have looked there first) and found where that was hiding I will try that this evening and post results.
David and Susan
Retired May 2017
South LOUISIANA
Old 09-12-2014, 06:25 PM   #19
TV Menu go to Setup icon, then down to AUDIO OUT, change to Fixed.
Sent from my HTC6500LVW using Forest River Forums mobile app
Tim
Old 09-12-2014, 06:27 PM   #20
Also setup this way if you are using the sound system inside your RV, instead of the TV speakers. Remember to turn the TV speaker to OFF.
Tim
