Old 08-30-2016, 05:33 PM   #21
Originally Posted by torino421 View Post
I was thinking it may be where that tag is attached too, but again I doubt it doesn't have one.
You're probably right. I would suggest he put a heavier one on.
Old 08-30-2016, 05:43 PM   #22
Agreed, I did both front and rear plus bilstein shocks and it made a huge difference on my rig. Tire pressure is also important, I run 65 up front and 80 in the rear.
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
torino421 is offline   Reply With Quote
Old 08-30-2016, 08:25 PM   #23
Roadmaster's Installed
I just had Roadmaster's front and rear anti-sway bars installed on my 2005 Forester and it made a HUGH difference. It's not perfect, but it made a big difference. Next I will put on the steering stablizer on.
toddlafond is offline   Reply With Quote
Old 08-30-2016, 08:36 PM   #24
I replaced the front and rear sway bars on my e450. I also put a Trac bar on and a safe t plus steering stabilizer. Those four things plus an alignment made a difference on my e450. Trucks still move me but I feel more planted.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 08-30-2016, 08:47 PM   #25
Land of the Midnightsun
jjSpeedwagon's Avatar
On our new concord I put on safe t steer and tightened air bags up some and big difference. Start with your steering then drive a while. You can add to much at once and make your rig so stiff it handels bad. There is a lot of over kill on this thread. Any high profile vehicle will sway and they should. ( some )
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 08-30-2016, 09:20 PM   #26
one handed drive
I have no stock or ownership in this company,
Airtab.com
I have installed them on the rear of my 2501 and the 12 ft. trailer I tow... 70 miles an hour and very little tug when I pass them or they pass me.
I can comfortably drive with one hand though I don't recommend it.
definitely improves stability, but can't say much about mpg since I pull a trailer with two motorcycles......
SatDAve36 is offline   Reply With Quote
Old 08-30-2016, 10:50 PM   #27
People swear by Airtabs, but I personally not know if they work. I hear alot of research behind them
robbdrell is offline   Reply With Quote
Old 08-31-2016, 01:21 AM   #28
benagi's Avatar
Helwig front and rear sway bars, Bilstein steering stabilizer, front end alignment. May add track bar later. Sure handles a lot better now.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 08-31-2016, 08:49 AM   #29
I'd be shocked if you don't have a factory front sway bar, look again!
I think I see it in your second picture.
You might be right Torino. It was almost night when I took the picture and unfortunately I did not aim the camera high enough when taking the picture. I will have to go back later and look in the daylight.
newRVer is offline   Reply With Quote
Old 08-31-2016, 09:03 AM   #30
This is actually the direction I am leaning. Alignment/caster change is done and am looking at upgrading the front/back sway bars with Hellwig units. And while the rear sway is off I will be adding a SuperSteer SS450 Trac Bar. At that point I will drive it the rest of this season and and if not satisfied will probably look to add a steering stabilizer (Safe-T-Plus?) before next season starts.
sway, truck
