Old 06-22-2015, 01:53 PM   #11
GM
bclemens's Avatar
Originally Posted by Creativepart View Post
Walking into that RV in the CW lot on our way to buy a part for our travel trailer really shook up our previous 13 years of travel trailer camping in a blink of an eye.
Obviously ecstatic to hear it. Welcome to the family.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 06-26-2015, 10:50 PM   #12
Creativepart's Avatar
Well today is the day. We' picked up our new RV this afternoon. Went over everything. Only two very tiny issues that were easily corrected. Outside of about an hour of useless waiting... why are RV dealers so unprofessional? We headed out to a nice State Park 10 miles from the dealership. That way if there are any problems we can be at the dealer first thing in the morning.
After setting up, having dinner, showering and watching part of a movie on the bedroom DVD we're ready for bed. No problems yet.
Tomorrow we get more organized, read manuals and test everything.
Our only complaint? Air condoning that is struggling to cool everything down in the 90 degree Texas heat.
Creativepart is offline   Reply With Quote
Old 06-27-2015, 06:27 AM   #13
Good to hear everything is working well so far. Do you have 13.5k or 15k a/c? We use a windshield sunscreen and run a fan which helps keep things cooler. We also insulated the a/c unit itself.
SkipnTerri is offline   Reply With Quote
Old 06-27-2015, 06:47 AM   #14
One more idea. I've talked to a couple of people who have removed the vents and found insulation and styrofoam scraps which block air flow. Also the last portion of ducting just goes into the front cap, so they put a piece of styrofoam in to terminate the path and say the air output increased greatly. Also did the same thing to the air outlet above the bedroom. I'm going to try this myself today.
Old 06-27-2015, 02:42 PM   #15
Here it is noon after our first night-not only did everything work, we had a HUGE thunderstorm with maybe 3 in of rain and NO LEAKS. Yeah!
Around midnight the A/C finally shut off when it finished cooling and ran normally. Today it seems to be keeping up OK. I should add as spoiled Texans we like it between 69 and 70.
So far everything is roses and branch water.
Old 06-27-2015, 02:52 PM   #16
Thumbs up
We have the 15K A/C. An outside window cover for the truck cab is first on our list for Monday.
Old 06-30-2015, 11:03 AM   #17
The one 15K A/C will always struggle in the summer in 90 plus heat. You will only be able to make small improvements to your cooling function, like those suggested above. Parking in the shade of course is the biggest difference maker. You do know that your fan has 2 speeds, Lo and Hi? I run the A/C fan continuously on high during the day and low at night. I never set the fan on Auto using the A/C. I only use the Auto function with the furnace during the winter.
Rocket City Gary is offline   Reply With Quote
Old 06-30-2015, 01:00 PM   #18
I'm not aware of the two speed fan. Perhaps I'm just seeing the "AU" for auto and not attempting to cycle through other settings. I'll take a look.
We have the RV in our driveway for the past 2 days, adding some items to the interior and it's been 91. We have a 30 amp plug installed in our garage so we have the RV plugged in and the A/C running. The first day it was very slow lowering the temp but today, it's 90 again and the A/C is keeping up just fine. I was just in there and it's 70 degrees according to our inside thermometer.
The A/C mostly seems to not be able to cool the RV down very quickly.
Our previous Travel Trailer was an Arctic Fox and they are super insulated for winter travel. The 13.5 btu A/C could cool that thing down in 2 hours. Of course it was about 4 feet shorter.
Old 06-30-2015, 01:08 PM   #19
Mine will only get down to 70 at about 3am. On a hot day it won't get lower than 80 inside. On my 2014 3051 you cycle thru the fan speeds with the control on "Fan" setting, not "Cool" setting. That speed then is used for all 4 choices" fan, cool, furnace, heat pump, until I reset it to another speed.
Old 07-05-2015, 09:23 AM   #20
To help reduce the heat load when we arrive at a campground in hot weather, I raise the engine compartment hood. The engine heat can go out there instead of through the poorly insulated doghouse and firewall.
Also, I flip the overcab bed down and hang a blanket behind the seats. This helps reduce heat from the cab. I do the same during cold weather. It looks tacky but it makes a difference.
If it's really hot, you can run the coach A/C with the generator in addition to the cab A/C as you drive to your campground to have a head start on cooling it down.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
