Old 01-22-2013, 05:05 PM   #1
GM
bclemens's Avatar
Pics of Lippert Above Floor Slide
Had a request.
ID:	23290   Click image for larger version
Name:	photo 5.JPG.jpg
ID:	23291   Click image for larger version
Name:	photo 3.JPG.jpg
ID:	23292   Click image for larger version
Name:	photo 2.JPG.jpg
ID:	23293   Click image for larger version
Name:	photo 1.JPG.jpg
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-22-2013, 05:34 PM   #2
Plain Old Member
Huge thanks bclemens. Those are priceless. Just what I was looking for. Third picture down was one of the adjustments I was referring to with the multiple holes for adjustment on the drive shaft. Not sure if this piece is accessible after removing the panel covered by carpet. Second option was the set screw you referred to. Where there's a will, there's a way. I'll give it a closer look when I get home, now that I know what I'm looking for. Thanks again.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 01-22-2013, 06:18 PM   #3
GM
bclemens's Avatar
I also wonder if you could just move the "in" stop on the rail or if that has to be perfectly square.
Old 01-22-2013, 06:26 PM   #4
Plain Old Member
Not sure. I'll be digging in a week. In case it didn't get noticed on the other thread, do you know when the 39 gallon gray / black tanks went into production on the SS and Forester? Mine was built some time in October I think. VIN 1FDXE4FS5CDA84762.
Old 01-22-2013, 10:10 PM   #5
GM
bclemens's Avatar
Well before that.
Old 01-30-2013, 08:45 PM   #6
Plain Old Member
Update. I managed to get to shaft with the multiple bolt holes for adjustment. Removed the bolt, rolled the back side out, slid the drive shaft over and resecured the bolt. Didn't really help that much, but it is just a shade better. I cannot find the "In" stops. The out stops are easy to get to. I probably fiddled with this thing for 3 hours and it is a little better, but still not like it should be. Where in the world are the "In" stops? If they are like the out stops and can be adjusted, this would solve the problem, provided you can get to them. All I can say as far as accessing stuff is WOW. Got the battle scars as a result. Might I suggest adding a removable access panel under the back dinnette seat, or anywhere else it might be handy just for this work? This is the first slide that was this hard to adjust. As for the gear with the allen set screw, not happening. I could probably get it loose, but I'm scared of the key stock falling out, plus it's way harder to access than that bolt was.
