Old 11-10-2017, 05:09 PM   #1
JimOneil43's Avatar
Pink Stains on Ceiling
We have found pinkish stains on the soft surface ceiling in our Forester 3051S, and they seem to have gotten worse over time. I was told that this is caused by the adhesive used in the ceiling getting wet. Has anyone else had this problem? I have contacted Forest River Warranty (Mike Jankowski) and am waiting for a reply. If you had this problem, how was it corrected? I don't see a leak anywhere and we don't have water dripping into the interior.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 11-10-2017, 10:23 PM   #2
Kirk S's Avatar
We have a 2017 Forester as well and love it.
Do you possibly live in a high humidity environment? That's all it would take if you park or store with no climate control (air conditioner, heater or vent fan depending on time of year, to keep air circulated).
It's not impossible that it could be pink mold since you say it has gotten worse over time.
We live in GA and although we haven't seen any pink stains, we always keep some type of climate control on that keeps our humidity level around the 50% range, the same as we keep our house.
I may be completely off base but trapped moisture can cause all kinds of finish issues.
If unable to run climate control, look into using dessicant like Damp Rid to absorb moisture. Get enough so you can swap them out. They can be dried and reused.
Some have color indicators that let you know when to change them.
I wish you luck.
Kirk
2017 Foretser 3051S
Kirk S is offline   Reply With Quote
Old 11-16-2017, 01:38 AM   #3
Kirk S's Avatar
Did you ever figure out what was causing the stains on the ceiling?
Kirk
2017 Foretser 3051S
Old 11-16-2017, 11:39 AM   #4
JimOneil43's Avatar
Haven't determined a cause yet...we have an appointment on 11/27 to take it in to Camping World for them to investigate further. It seems that the general consensus in talking to Forest River warranty dept and the folks at Camping World is that it is caused by moisture from somewhere. It could be high humidity possibly....we live in Oregon and it does get pretty damp and humid here in the winter, however we have kept a small heater going in it all last winter. There doesn't seem to be a leak, but they are going to check that out too. We'll see, but I imagine that that section of ceiling covering will have to be replaced. $$$?
Born April 18, 2016
GO DUCKS !!
Old 11-16-2017, 08:05 PM   #5
Mine was a slow long term leak. Pull the vinyl down and stick your hand in to feel for moisture.
AbdRahim is offline   Reply With Quote
Old 11-17-2017, 10:47 AM   #6
JimOneil43's Avatar
What did you do to fix it? Did you have to replace the ceiling covering?
Born April 18, 2016
GO DUCKS !!
Old 11-17-2017, 05:04 PM   #7
Hello Folks,
I'm getting a new 3051 soon so I thought I would ask a couple of question.
1)
Could you explain that to me as I dont understand that, why is there adhesive in the ceiling??
2) I never heard of pink mold...is that dangerous?
3) Is there a spray or compound that one could use to prevent something like this?
Thanks, Jake
James Jake is offline   Reply With Quote
Old 11-17-2017, 05:51 PM   #8
Platokidd's Avatar
Originally Posted by James Jake View Post
Hello Folks,
1)
Thanks, Jake
Found this info on on mold and pink mold.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Platokidd is online now   Reply With Quote
Old 11-17-2017, 06:40 PM   #9
JimOneil43's Avatar
Hello Folks,
1)
Thanks, Jake
(1)The reason there is adhesive (glue) in the ceiling is that is how they attach the soft surface ceiling material to whatever is underneath it.
(2)I don't believe it is mold...I was just told that the adhesive turns pink when wet.
(3) Don't know, but I doubt there is any spray that would prevent it, as the pink stains are coming through from the inside of the ceiling covering.
Born April 18, 2016
GO DUCKS !!
Old 11-17-2017, 06:59 PM   #10
Platokidd's Avatar
Hopefully you/they can stop it from getting wet or mold may be in your near future.
Seasonal
