Old 09-30-2015, 08:53 PM   #1
Sagecoachdriver's Avatar
Porch light and Stove vent light to LED
The porch light and stove vent light are both non LED and not the conventional bayonet type either. Are there direct LED replacements for these bulbs without having to change the sockets? I saw something that looks like this at CW but in LED, expensive $19 each.
first is porch, second stove top vent lamp. Click here for CW's LED light.
LED Multidirectional Radial Tower Bulb with wedge mount connection - Diamond 52609 - Light Bulbs - Camping World
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 10-01-2015, 07:42 AM   #2
waiter21's Avatar
I used one of the 36 LED panels I got on e-bay to replace my porch, stove, and all the lights in my Mirada..
Exterior entry light replacement | 2001 Coachmen Mirada 300QB
Upgrading coach lights to LEDs | 2001 Coachmen Mirada 300QB
Adding a dimmer to LED lighting | 2001 Coachmen Mirada 300QB
Adding bathroom light wall switch converts ceiling fixture to LOW-MED-HIGH | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-01-2015, 08:24 AM   #3
Those lamps are 921's. If you look for LED replacements for that number you'll find many.
They make either barrel assemblies similar to the shape of the original bulbs or they make flat assemblies. Just be aware that the flat assemblies won't fit in all fixtures.
Gotta go campin!
Old 10-01-2015, 10:40 AM   #4
The ones in my photo get so hot very quickly. I'm surprised they don't start a fire, especially the black one from the stove vent lamp which puts out little light.
What lumens should I shoot for, will something in as low a 100-160 work or do I want 260? I guess space available for the bulb may dictate that.
Old 10-01-2015, 11:00 AM   #5
I'd go for as high a lumen as you can find. If you limit your search to lamps that use the greatest possible number of 5050 or 5630/5730 LED's you'll get the highest amount of light out of the lamp.
I replaced all the bulbs in our RV with 24 5050 LED disc shaped lamps in bright white. I had to use a 42 LED bulb in the range hood light because of the limited amount of space. It's not very bright, but it's better than the incandescent lamp that was there.
Gotta go campin!
Old 10-01-2015, 11:49 AM   #6
There are many LED 921 type bulbs available. I changed both out and am happy with the results. The bulb over the stove isn't quite as bright as it used to be which we actually prefer. Some LEDs can cast a harsh bright light if they are too bright or the wrong color temperature.
I changed the outside porch light to an LED motion sensing light. Works well.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
ebcobra93 is offline   Reply With Quote
Old 10-01-2015, 12:04 PM   #7
MilCop4523's Avatar
we've switched both of our trailers over to LED's and now i can see without getting a sunburn from the heat.
ordered on line out of China where all the bulbs appear to com eout of. 30 count was $38 Canadian shipped.
get the brightest white you can find. Natural daylight is the easiest to use.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 10-01-2015, 01:02 PM   #8
Dahagen
Get the China made wedge mount from Amazon. 20 will cost the same as 1 at your local retailer. And watch lumens (the more the brighter) and I like natural daylight.
dahagen is offline   Reply With Quote
Old 10-01-2015, 01:41 PM   #9
How would I know
I have a 2011 Rockwood 8317RKSS how can I tell if the bulbs are LED?
Virginia Rocker is offline   Reply With Quote
Old 10-01-2015, 02:35 PM   #10
Remove some of the lens and if the bulbs are clear glass they're not LED. Since the mfg's are still putting incandescent bulbs in the newest RV's my bet is that yours are incandescent as well.
Gotta go campin!
Old 10-01-2015, 03:50 PM   #11
You might want it take a look for them on line at m4led.com. (RV Retrofit LED Lighting). I have ordered from the twice and they seem to be a very good supplier. Last order placed on sat and was in mail box on wed. (Ca. to Ga.) And they have always sent a free koozie!
hdmtnrider is offline   Reply With Quote
Old 10-01-2015, 03:57 PM   #12
Going to the Pomona RV show next weekend. They usually have a vendor selling them.
Old 10-01-2015, 03:58 PM   #13
CABIN Brite, LEDS they have a super led bulb for over the stove! Contact them! Youroo!!
Old 10-01-2015, 03:58 PM   #14
vwexpert's Avatar
Wedge Base RV Replacement LED Lights
I ordered two 921-10-5630 bulbs...I'll report back how these work.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 10-01-2015, 04:52 PM   #15
Dahagen
LED bulbs do not get too hot to touch.
Old 10-01-2015, 05:13 PM   #16
My 2016 Roo had all LED from the factory, except for above the stove and the outside "porch" light. I've since changed those out.
Eric & Abby
Old 10-01-2015, 05:34 PM   #17
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
I used a pair of these: works great.
Amazon.com: RioRand® 2 pcs Set Waterproof Aluminum High Power 6W 6000K Xenon Slim COB LED DRL Daylight Driving Daytime Running Light Lamp For Car SUV Sedan Coupe Vehicle (White): Automotive
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 10-01-2015, 06:49 PM   #18
vwexpert's Avatar
Paulie1138...can you post pictures of your install?
Old 10-01-2015, 07:23 PM   #19
Recently new!
Paulie1138's Avatar
VW, will do soon. Not much to see, other than a ton of light....lol. I took a wedge base pigtail from one of the overhead 48 LED panels I bought, tied in the two of the driving lights, pulled back the plastic light cover, and peeled the self stick adhesive and stuck them in place. Put the cover back. Much nicer, as the lite is spread out over a longer and wider space. It is almost too bright, so I am thinking of taking one out.
I just had surgery, so I will post pics in a few days.
2001 Ford F-250 7.3
Old 10-01-2015, 07:35 PM   #20
Get with the times
The Bayonet end i think you refer to has not been in use in cars or rv's for some time, the buld you have shown is a 912/921 bulb very common bulb, and yes any buld in your house, car or rv has a LED buld aviable just head over to LED light bulb, LED light bulbs for home use and cars and order any bulb you want at unbeatable prices
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
light, vent, led
