Old 12-15-2015, 06:18 PM   #1
KJcachers's Avatar
Portable air compressor?
Give me some recommendations for a portable air compressor I can use for the tires and the airbags. Thanks in advance!
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 12-15-2015, 06:43 PM   #2
RETIRED
n-e-d's Avatar
Porter Cable oil less 1.5 gal,small I plug it into Dyson recepticle in rear storage and have 2 25' hoses- quick connects on all fittings
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 12-15-2015, 06:44 PM   #3
go to home depot and pick up a small compressor (150psi) worked for me
rekwiat is offline   Reply With Quote
Old 12-15-2015, 06:50 PM   #4
vwexpert's Avatar
This is what some of us use for the rear air bags.
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 12-15-2015, 06:52 PM   #5
12Volt 150 PSI Compact Air Compressor is the one I have used, not fast but priced low. The screw on air chuck was akward and I replaced with a lock on type. The real problem was with the tire valve extentions which didn't seal well with the air chuck, even at the truck stop. Seems the capless extentions don't work well. Also very akward to get in the space allowed by the wheel covers. Still working on it though.
Harry & Alice
Furkid Spruce
2014 Sunseeker 2650s
Friend of Bill and Lois
since May 30, 1975
Happywanderer is offline   Reply With Quote
Old 12-15-2015, 07:42 PM   #6
Blackhat6mike's Avatar
Check with Auto Zone for a Slime compressor. There are several levels of pumps and they are not expensive. I have three different units and they have all worked well over the many years I've used them. IMHO
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-15-2015, 07:50 PM   #7
nomad297's Avatar
VIAIR 450P RV
Bruce
Old 12-15-2015, 07:53 PM   #8
Originally Posted by nomad297 View Post
VIAIR 450P RV
Bruce
X2
2016 Siverback 33IK
Old 12-15-2015, 07:59 PM   #9
Done with this
I went El Cheapo. If is screws up, it's not to expensive to pitch it away. Works pretty good...
12V 100 PSI High Volume Air Compressor
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 12-15-2015, 08:11 PM   #10
Here is a link to an earlier discussion as well as a link to the model I have. There are many good unit out there-and a lot of junk.
Air pump
pjnlorrie is offline   Reply With Quote
